PC Based Computer music servers, crossovers, and equalization
Rasberry Pi and active crossover revolution
Old 14th December 2012, 07:26 PM   #61
Crumboo is offline Crumboo  Sweden
Anyone know if the Raspberry Pi is capable of running BruteFIR yet? It would be a very nice solution!
Old 14th December 2012, 07:53 PM   #62
Neil_J is offline Neil_J  United States
No effin' way, BruteFIR liberally uses the Intel SIMD instruction for the convolution process.. That ain't gonna work on the Pi with an ARM processor. If you recompile it without the intel assembly instructions, it *might* work, but likely won't do so with decent throughput.
If you or anyone else do get it to work, please post details here
Old 9th January 2013, 11:00 PM   #63
David Wareing is offline David Wareing  Wales
Just got Brutefir working tonight. Doing a 2x2 convolution with 2048 sample IRs. It seems to use about one third of the available processing power. I am doing Ambiophonics from a S16_LE raw file to an external soundcard, or HDMI., so far; I only managed to get two channels out from HDMI, the last time I tried, some time ago.
Using 2012-12-16-wheezy-raspbian.zip.
I could not get Jconvolver to work because Jackd is broken, but there seems to be a cure for that now..
Audacity works too.
Old 9th January 2013, 11:49 PM   #64
Audacity works too.
Very interesting, great work. Are you doing any assembly-level CPU optimization, or straight C code?
Old 10th January 2013, 08:37 AM   #65
I still have my linux/brutefir/alsa/jack L plates on...
After the fresh distro install, and upgrade, I think it was just "sudo apt-get install brutefir"
The latest distro, with hardware floating point whatnot, seems about three times faster than when I first tried convolution - I only got fconvolver to work then, and it took ages to get any sound out at all. I gave up then!
I read that there is a circuit fault with the internal stereo jack sound out, that may be fixed with later boards.
There is no alsa driver for my usb Quad Capture soundcard so I am using an old Soundblaster, but I don't think it can do input and output at the same time.
I beleive you can overclock, but I have not done so.
David.
Old 10th January 2013, 10:00 AM   #66
madtecchy is offline madtecchy  England
Originally Posted by oublie View Post
Its a home cinema still in build stage 6 15" sub 64 mids 200 tweets1080p projector with screen using computer connected Xbox kinect to control via voice and motion early days but I will get there. atm the idea of spending 25 per speaker on good quality crossover technology embedded in the stud walls is pretty good compared with the insanity of purchasing something which I don't know and don't trust
OMG. That many speakers ... i can tell it is early days LoL
Old 10th January 2013, 10:14 AM   #67
ps. This might be useful:
Jackd Raspberry Real Time Audio - My-Lab
I have not actualy got it working yet, but it does not instantly fail like the 'standard' one does on the Rpi. Be careful not to overwrite it by installing QjackCtl, for example.
Old 15th January 2013, 12:15 PM   #68
Gadgety is offline Gadgety
I read on the RPi forum that the RPi only supports up to 11 bits of audio.
Raspberry Pi • View topic - How to get high quality audio from R-Pi?
Misinformed (knowledge tends to change over time) or is this correct?
Old 16th January 2013, 06:37 PM   #69
philpoole is offline philpoole  England
If anything, you're referring to the analogue output.
Don't panic.
Old 16th January 2013, 07:06 PM   #70
Subjectively it sounds fine using the HDMI (stereo only.) or the digital coax out of a USB soundblaster to an AV receiver.
I case I was deaf or deluded, I also recorded a -60dB 1kHz tone with Audacity and played it with aplayer on the Rpi to the USB Soundblaster, which was connected via the digital (coax) out to the digital input of a Roland Quad Capture. I recorded from this using Audacity. The only difference I could see from the original was increased noise (due to added dither?), but the (-60dB) signal was still about 60dB above the noise.floor. (CoolEdit Frequency Analysis FFT size 65536)
Seems ok, using a half-decent external soundcard..
A 32 bit float wav output file (after two soundcards) is here, for a short while:
https://www.dropbox.com/s/elshm36skg...0-tone-out.wav
Rasberry Pi and active crossover revolutionHide this!Advertise here!
Tractrix in 1*Pi and 2*Pi revintage Multi-Way 21 26th August 2011 09:37 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Active Crossover soundNERD Chip Amps 5 24th September 2003 01:39 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
