"assi" revised and updated "how to install his amafir/hdmi_play on raspbian jessie"
http://audio2.amanogawa.info/article/raspi/07.html
Though it was written in Japanese, but you can see command line and guess what happens.
Hello, I've added configurable bitdepth support and HDMI channel mapping into hdmi_play2, it-s here:
https://github.com/antorsae/hdmiplay
Usage:
hdmiplay samplerate bitdepth [mapping]
e.g.
hdmiplay 44100 24 01234567
Mapping parameter is optional, in governs how to map between the 8 incoming channels and 8 hdmi out channels:
0 -> 0
1 -> 1
2 -> 2
3 -> 3
4 -> 4
5 -> 5
6 -> 6
7 -> 7
in my case I am using it in conjunction with Brutefir as a digital XO for the Orion active speakers feeding a 7.1 receiver directly with power amp assign, I had to use mapping: 01324567 to be able to map the "C" channel (the LFE channel is not power-assignable in my receiver).
Code is ugly as hell but I may be useful for someone.
Usage:
e.g.
0 -> 0
1 -> 1
2 -> 2
3 -> 3
4 -> 4
5 -> 5
6 -> 6
7 -> 7
Can you share more details of how you setup [playback mechanism]->BruteFIR->hdmiplay? Did you use JACK, or pipes, etc?
Wanted to add to this thread.
It is now possible to get 8 channels out of a Pi (check here).
I guess you don't need more then 3 channels per speaker, and one or two for subs. Do you think it is possible to use one Pi for two 3 way speakers and a sub ? It would be nice to have the Pi inside the speaker ... however that would make it more difficult to operate the other speaker without lots of wires dangling out.
Matt
Matt
Matt
Thanks for posting about the new 8-channel project from Flatmax. I have the Pi HAT and it's not bad. Had some setup and config issues that require re-running some setup code after each reboot (or so it seems).
I would be interested to see the noise and THD performance of the 8-channel version...
If you use IIR filters you can process 8 channels on the Pi, although I am not sure if this would work at 192kHz. There many LADSPA IIR filter offerings, including my own (see my sig line below). Ecasound would work well because input and outputs would run at the same sample rate, and this would remain the same.
