Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Closed Thread
Old 25th April 2012, 12:44 PM   #291
phofman is online now phofman  Czech Republic
Originally Posted by kyrill View Post
Before this year is over more silver internal pc connects will come at the market.
I wonder what your next silver product is gonna be.
Modern PSU cables are detachable these days - what a chance. Of course the fixed ones would be no market opportunity, those who buy hand-made silver sata cables have no knowledge and equipment to solder new wires to their existing PSUs.
Cables from the MB to case controls (leds, power switch) - they do not carry any signals, but who cares. Silver is silver, and the X threatens.
Fan wires - PWM control, ideal candidates. But bad luck, they are soldered too. Perhaps you could sell complete fans with silver wires. And the fan coils could be silver wound too.
And that's it, no more interconnects in modern PCs. No more opportunities for bussiness to rich clueless audiophiles. But you will certainly come up with something new, creative, not from the dark ages.
Old 25th April 2012, 12:44 PM   #292
kyrill is offline kyrill  Netherlands
"Say you add enough error correction such that on average only one error every year passes all the correction, isn't that negligible? "
factor X has nothing to do with "errors" the zero's and ones's do not need correction because of this "X" "X"is independent of the digital world and completely "neglected" by digital hardware. ONLY when somewhere digital is converted to analogue it "pops" up. It will always pop up in some degree as it can never be zero in praxis if bit perfect is bit perfect how can mac sound different then windows going to the same dac and stereo setup behind it?
Why does windows on a separate hdd ( USB/SATA converter enclosure) with LINEAR but good power sound triple better than windows insde the PC with default power? Add to that all music files on a similar separate enclosure with clean power and then you realize the PC may reach or surpass a high end turntable and MC given a superb software player not JRiver or Foobar
Old 25th April 2012, 12:48 PM   #293
Modern PSU cables are detachable ...lete fans with silver wires. And the fan coils could be silver wound too.
Listen yo yourself, that is Dark Age thinking. Try to understand what inductive research is about
Old 25th April 2012, 12:49 PM   #294
SY's Avatar
The man does not offer a cable which has been laid in the moonlight for 12,75 hrs and kissed by a beautiful maiden so that it will sound better. That would be a different matter.
Yes, that method lacks the velvet.
If there's a sucker born every minute, where do the rest of them come from?
Old 25th April 2012, 12:56 PM   #295
This is no research, but a heap of nonsenses. Seasoned researchers would not even reply to this thread. There is a rule in research - always verify your findings, your observations - be it inductive or deductive. How did you verify the audible impact of sata cables (or generally silved PC interconnects)?
Old 25th April 2012, 01:33 PM   #296
Simon B is offline Simon B  United Kingdom
Given that the proponents of this ordure are now using a link to the writings of someone publicly declaring himself to be "a philosophy professor with an interest in experimental methodology, especially in psychology and psychiatry"
may I make this suggestion:
Old 25th April 2012, 01:34 PM   #297
I give monthly lectures on methodology of research at the university. Philosophy of science and methodology is one of the courses that I teach. What you really do not comprehend is that your thinking is in "defense mode"
For some reason "silver sata cables" attacks your rationality. Test the cable you will find a perfect but silver sata cable. And there positivist science stops what you and those who think like you so desperately try to extend. A/B blind listening tests in the subjective domain of listening is a hoax. Conclusions can only roughly made as yr ears hoe perfect they are and way beyond any mechanical sensitivity are also linked to the one who interprets his hearing. Only that as a combination, can be "blind tested"
Eskimo's are well known to distinct and therefore able to see more than 30 kinds of snow. Put yourself next to an average Eskimo in Greenland in a very snowy landscape and another person will do an A/B test between you and that Eskimo of how many kinds of snow really can be perceived. And take all yr Czech friends with you and let them join the test.. Poor Eskimo, he must be a clever salesmen trying with a beautiful clever marketing pitch to persuade you to accept his findings as he is the only "fool" who claim to see so much.
What is true for the eye is also true for the other 4 senses.
Simon B ah ya I began some posts ago what is there to say to the blind and deaf? So I will not react to you anymore
Old 25th April 2012, 01:39 PM   #298
I had plenty of incompetent lecturers at college. Not that I'd wish to question your competence of course.
Let us hope that the end is near.....
Old 25th April 2012, 01:51 PM   #299
neutron7's Avatar
Actually dark age thinking is preists trying to make people believe in something which there is no evidence for (factor x) and denouncing science which can be proven right before your eyes.
One thing which does exist and has been proven over and over, is the placebo effect. There is your factor x.
Old 25th April 2012, 01:54 PM   #300
OllBoll is offline OllBoll  Sweden
kyrill
And this factor X can of course not be measured and is always present?
Lets redo what i proposed before:
But after you read the music files from the hard drives you print out the bits, write them down on a paper then let one of your friends input them back into the computer and then send them to the DAC. (sure it's impractical with so much information but lets ignore that in this case)
Do you seriously still mean that a mythical factor X which is purely analogue is still present and affected by this silver SATA cable even though all the bits are correct and the path has been decoupled by a human in between?
Closed Thread
SATA Cable toufu Digital Source 3 20th August 2010 07:54 AM
25 pair cat 5 cable for speaker cable? mpmarino Parts 19 3rd March 2006 04:46 PM
hand made - attenuators karma Everything Else 9 20th May 2004 05:15 PM
pictures of the best hand made speakers shadiedog87 Multi-Way 14 30th December 2003 02:41 AM
Copyright ©1999-2013 diyAudio
