PC Based Computer music servers, crossovers, and equalization
wav file problem- compatibility?
Old 7th December 2011, 06:48 PM   #11
boris81 is offline boris81  United States
WAV is more of a guideline than a defined structure.
The format of how the data is stored must be described in the file header.
Most people happen to use the original structure so there are no problems when reading the files but WAV is so flexible that you can come up with your own data structure if you wish. The software you are using might be arranging the data in a way that players can not read.
wav file problem- compatibility?Hide this!Advertise here!
Need the best 1 khz impulse wav file gaetan8888 Everything Else 7 26th December 2009 02:39 PM
Convert hi-res 24/96 audio dvd to wav file? protos PC Based 5 7th October 2009 11:37 PM
.wav file limits? Netlist Digital Source 5 2nd December 2006 07:16 AM
SwitcherCAD .wav file I/O I_Forgot Everything Else 4 19th May 2006 01:04 PM
Large .wav file problem Centauri Digital Source 17 24th January 2004 12:19 PM
Copyright ©1999-2017 diyAudio
