PC Based Computer music servers, crossovers, and equalization
Is it possible to do a 4-way crossover with kx drivers?
Old 30th November 2011, 11:21 PM   #1
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Default Is it possible to do a 4-way crossover with kx drivers?
I have a Audigy 2 ZS (platinum, I think). All I have left for outputs are SPDIF (same as digital output, I think). And then the soundcard has a headphone output that come off the card and goes to the front piece (if I had one).
Can I use this headphone out as a fourth output (subwoofer)? If not, can I use digital output? Is it easier just to get a card that has 4 outputs and works with kx drivers (I don't think there is one).
Old 1st December 2011, 03:02 AM   #2
dangus is offline dangus  Canada
I don't know. But here's a page with a clear and hopefully correct explanation of how to connect all 7.1 analog outputs. FAQ: Connecting the Audigy 2 ZS to your receiver - Page 7 - AVS Forum Evidently I was mistaken in thinking that a "camcorder" or iPod cable would work... Creative puts ground on one of the rings.
If you want 4 stereo S/PDIF outputs, those can be found on the AD_EXT header.
3 PCM outputs can be had from the digital out jack, according to this diagram. It appears to use a normal camcorder style cable with the ground where you'd expect it to be. http://ask.creative.com/wwimages/aud...oundcard19.jpg
Old 2nd December 2011, 02:42 PM   #3
Jimmy154's Avatar
I could try the mic output and see how it works, but I don't know which pins they are on the soundcard connector.
Old 2nd December 2011, 07:36 PM   #4
boris81 is offline boris81  United States
Audigy 2 ZS is 7.1 meaning that it has 8 outputs.
LineOut1 = L-R
LineOut2 = CL-CR-BR
LineOut3 = C-S-BL
or something similar
However you need a special cable to use the extra 2 channels in the back. it looks like this and it's usually used for playing video from digital cameras.
I haven't tried the headphones output but it might work. Also you can buy a second card and use them together to get more channels.
Old 6th December 2011, 04:31 PM   #5
Jimmy154's Avatar
Yes, that's what it look like, then it has a panel that goes to the front and has a headphone output. I'm hoping to use that headphone output, if I can figure out which pins are the headphone stereo output and ground on the sound card connector that goes to the front panel. Or I have to buy the front panel and figure it out that way, which I would rather not do. Hopefully it will work.
Old 6th December 2011, 04:40 PM   #6
Jimmy154's Avatar
I think it's the white connector for this particular card. I don't know which outputs are for the microphone.
Old 7th December 2011, 05:04 PM   #7
You didn't understand what I was saying. I am already getting 8 analog outputs from my Audigy 2ZS and I don't have the front panel.
You don't need the front panel to get 8 outputs, they are already on the PCB bracket (2+3+3 = 8 = 7.1).
LineOut1 = 2 outputs = Left + Right
LineOut2 = 3 outputs = CenterLeft + CenterRight + RearRight
LineOut3 = 3 outputs = Center + Subwoofer + RearLeft
(I might have them mixed up)
Headphone outputs usually have an amp so they might have different voltage that the line outs.
Old 10th December 2011, 05:25 PM   #8
Jimmy154's Avatar
Right now I'm getting two channels per output. So six channels total. The channels are front (right and left), rear (right and left), subwoofer and center out. I also don't see any more analog channels (other than headphones) on my kx drivers digital sound processor.
What am I missing?
Lol, I'm so stupid. Looking at your kx DSP I noticed that I used way too many crossovers. Also you seem to have way less . . . ummm . . . functions. Since I don't know what most of them to I didn't get rid of any of the useless ones. Can you email me your DSP? I think once I have the basic setup I can modify it.
Old 10th December 2011, 08:25 PM   #9
You need 2 of these cables to take advantage of the extra channels.
http://http://www.buy.com/pr/product...lerid=24351715
I built a very simple DSP routing with the basic components.
It's NOT TESTED so be careful. Turn down the volume and try the outputs.
It's missing routing for LineIn and MicIn which you might want to use at some point.
Rename the .ZIP extension to .KX - it's not a zip file.
Old 10th December 2011, 09:23 PM   #10
Jimmy154's Avatar
The link is not working for me, but I think I know which cables I need. I wanted to confirm the channels exist because I do not see them in the "epilog." Maybe I will figure out which ones or where they are.
Thanks for the files. I really liked UFX EQ-P5, but I can't use it with kx 3550 and I need 3550 for windows 7, I think. At least they fix some windows 7 compatibility issues in that version.
I like you speakers.
Is it possible to do a 4-way crossover with kx drivers?Hide this!Advertise here!
Soundblaster kx driver as a crossover? JaRoD Digital Source 8 10th August 2006 10:41 PM
Kicker: KX vs. SX NaftaliG Car Audio 0 11th December 2004 08:21 PM
KX drivers Raka Multi-Way 29 3rd September 2004 07:28 AM
KX this may seem blindly obvious 5th element Multi-Way 11 19th March 2004 03:06 PM
To Nappylady on the KX and the SBlive and anyone else 5th element Multi-Way 6 9th September 2003 11:59 PM
