PC Based Computer music servers, crossovers, and equalization
How to set up an internal sound Card?
Old 23rd October 2012, 07:07 PM   #31
geraldfryjr is offline geraldfryjr  United States
You can save the drivers anywhere you like.
Say even in my doc's, in its own folder.
Then when Device manager ask's you for where they are, you just point it to the directory (folder ) they are in, and then it will recognize that it is a driver and install it into the system.
jer
Old 24th October 2012, 02:19 AM   #32
alant4321 is offline alant4321  Canada
alant4321's Avatar
Originally Posted by AndrewT View Post
Im stuck at ref 1.
Creative Emu1212 soundcard is quite old at least five years ago. I am doubt if it supports Win 7 64 bit in your new computer. Contact Creative to confirm and ask for correct driver. Current emu1212m model works fine for Win7 64 bit. Normally, driver disc is supplied with soundcard when purchase. Anyway, If you download correct driver from website, then computer will detect it at correct bus interface such as PCI slot and don’t worry about PCIe.
You can download the software driver into your computer at anywhere you like, normally at the folder of My Doucment/Download. Then, click the driver to install into your computer and reboot it. (i.e. Not necessary to update driver again) If there is no “question mark” in system, then your soundcard in ready to use.
(PS: For Scotland event, Barcelona (Spain) normally won Celtic (Scotland) both my favor football teams, but surprisingly at last 90mins by 2:1 by watching TV in UE Champions last night. All results of UE Champions are normal in my prediction)
"To work smarter, but not to work harder." by alant4321
http://www.teco-audio.com
Old 24th October 2012, 03:09 AM   #33
sippy is offline sippy  United Kingdom
Win7 has a MASSIVE amount of decent features, some for 'Tech types' and some for us 'Mortals', takes a while to learn where they are though.....
Hi Andrew,
You are able to run XP and Vista software in compatibility mode in Win7!!!!!!!!
Download driver for your device.
Open folder containing driver, Left click highlight / right click to bring up menu and select Properties.
Click Compatibility - Check 'Run this prog in compatability mode for:' and the drop down menu will give a list of Op systems.
Select Win7.
Check box below Privilege level so it runs as Admin.
Click Apply then OK.
Re-highlight driver in folder, Right click and select 'Run as Administrator'.
Hope this helps.
Old 24th October 2012, 08:42 AM   #34
R.I.P.
I got a reply from Creative this morning.
They are confirming what the download website says. Use the beta driver for my PCI to run with Win7 64bit.
I am not prepared to use again the disc that came with the hardware. It is reported by my AVG that it has a Trojan Horse buried in it. And it is for pre win7.
regards Andrew T.
Old 4th November 2012, 05:05 PM   #35
ben_lesmana is offline ben_lesmana  Indonesia
Have you got it to work, Andrew?
Old 4th November 2012, 05:10 PM   #36
R.I.P.
not spent significant time on it yet.
The on board sound is now working. But many times it appears silent. eg. today I have not heard a pip, yet on other days it tells me lots.
regards Andrew T.
Old 24th April 2013, 10:31 AM   #37
triplej is offline triplej
Hi Andrew,
I'm with Pano re settings.
Try using a different Fft Program. If that dosent work cut you,re losses. I purchased MI by V?.... And have not looked back. This coupled with the EMU 0204 is the best $200 DIY audio $ I've spent.
How to set up an internal sound Card?Hide this!Advertise here!
PC sound card sound chips kaluchka Chip Amps 6 20th June 2011 03:48 PM
Internal TT sound card rwm8088 PC Based 4 16th April 2010 05:25 PM
Internal sound card change to external? EmergencyDpt Digital Line Level 4 31st August 2008 06:57 PM
Which sound card? MMeche Digital Source 1 28th June 2008 11:17 PM
Can your sound card do this? jackinnj Everything Else 25 7th November 2005 11:32 PM
