| PC Based Computer music servers, crossovers, and equalization |
#12 |
Proud Union Member
You would need two systems obviously, but yes the transmitter will accept a line level signal and tge reciever will run on anything between 8-18v dc, so it's an option. Plus, those guys are great.
#14 |
i think you're over complicating things by having the left/right independent and having to deal with sync. i think id do it like this, if your field is in wifi range:
stream from house to field using wifi. receiver could be anything that can act like a pc (hacked router, embedded platform, netbook) if you still want a large separation between speakers, use a short-range wireless solution like off the shelf wireless speakers, bluetooth etc |
#15 | |
#16 |
Can the speakers be linked by a wire? If so, just use a local lossless source. Like a Rockboxed iPod, or Sansa Clip+. Or a portable CD player with optical out. It's not a common feature, but they exist.
If using WiFi, you can probably use VLC to serve a stream, and configure each receiving VLC client to default to that stream. Or if cost is really no object, build a bandstand and put musicians in there. |
#17 | |
MikeD |
#18 |
I want to use wireless hookups and speakers with class d amps running on a 12v battery for family parties and movies in the field via projector...
#19 |
Sometimes a square peg fits a round hole just fine
why is this being made difficult? use wifi, personally i would use something like airport express, perhaps with an Apple TV for the video and if you cant use it directly for the audio as well, just use separate base stations, they have USB or toslink/mini analogue combo output.
No need for separate channels, they will both receive the same stereo signal and you just use left or right depending on which side speaker it is. i'm sure there are other similar non-apple solutions if you are not in favor of the 'white goods'. the airplay receivers will work just fine with a windoze pc on 802.11n. you can use an iphone, ipad, or similar netbook as remote, in fact the apple TV has its own remote. if its too far for wifi i dont think it would be that hard to make a headless mac mini or similar run on batteries out in the field and all the same options apply. |
| wireless audio | yash gupta | Everything Else | 11 | 17th May 2010 10:46 AM |
| Wireless audio? | Lostcause | PC Based | 17 | 8th February 2010 05:53 PM |
| 2.4GHz wireless audio - true lossless audio | Kay | Digital Source | 0 | 30th January 2008 10:22 AM |
| Wireless Digital Audio System | audio_steve | Digital Source | 4 | 3rd January 2004 12:28 PM |
| Wireless Audio/Video setup | gunmasterg9 | Everything Else | 0 | 30th July 2002 04:49 AM |
| Page generated in 0.10160 seconds (80.27% PHP - 19.73% MySQL) with 10 queries |
