| PC Based Computer music servers, crossovers, and equalization |
#31 |
I have the PCM2706 (USB->I2S) and PCM1794A (I2S DAC) and am looking at options of what to do and have a question about a possible pairing of the PCM2706 with the playstation as a USB DAC.
Given a correct circuit for the PCM2706, would i be able to just connect the 4 I2S lines directly to the AK4309AVM (+remove original I2S connections) and use it otherwise as-is on the playstation? (for USB DAC only). |
#33 |
I've just spent two hours researching low budget USB DAC's and the Behringer definitely seems like one of the best alternative out there.
#34 |
The FIIO D3 does really sound good--$28 on amazon. It works up to 192Khz @ 24 bit. I have tested it with up to 96/24 and it works fine.
It sounds better with an external regulated power supply; it comes with a cheap switching 5v wall wart. I got the 12V 3A pyramid regulated power supply off amazon for $28--the one that people rave about for use with the $300 or so V-DAC. Just use a voltage regulator like the LM7805 or the LM317T--along with the .33uF and .1uF input/output caps--to bring the voltage down to 5 volts. There is noticably more clarity, separation, less mudiness with this mod. It has SPDIF input. My computer has a SPDIF output so it works great for me.. you can get a SPDIF to USB board or device and use it with it if needed. Last edited by audiogeekess; 7th December 2011 at 10:53 AM. |
| Advice need: Wav/flac Reader with decent DAC | Tony09 | Digital Source | 29 | 23rd August 2011 09:19 PM |
| Really!? - no decent diy DAC with basic 5.1/PCM functionality as well? | Galgo | Digital Line Level | 26 | 26th June 2010 10:18 PM |
| PC crossover with IIR filters, affordable? | thadman | Multi-Way | 9 | 19th April 2007 11:06 AM |
| Wanted: External, portable CD-ROM or DVD drive; decent USB DAC, portable speakers. | Spasticteapot | Swap Meet | 0 | 31st May 2006 02:13 AM |
| decent pc soundcard with multiple outputs? | zag0r | Digital Source | 6 | 10th May 2004 04:00 PM |
| Page generated in 0.07722 seconds (72.36% PHP - 27.64% MySQL) with 10 queries |
