PC Based Computer music servers, crossovers, and equalization
Decent affordable DAC for PC?
Old 30th October 2011, 08:57 PM   #21
sfasf is offline sfasf  United Kingdom
So, how does I2S work in practice? Take for example the RasberryPi board with the PS1's DAC (schematic @ http://feuerbacher.net/DogBreath/PS1...gsstufePS1.jpg )
What has to be connected to where, and what else is needed? (other than power, of course).
Old 31st October 2011, 02:05 PM   #22
phofman is offline phofman  Czech Republic
RaspberryPi as of the currently available information does not seem to have I2S taken to the external header, if I look correctly. But all this is preview information, we have not seen the final board yet. But the pins are present, hooked to TLW4030 codec directly.
Here is an insightful discussion on hooking beagleboard to external codec, regarding changes in the alsa linux driver. The point is their external codec has a different master clock frequency than TWL4030 and requires re-configuring the clock divider of OMAP. Most likely you would have to do the same as the master clock 25MHz of TLW4030 is very rare among standard audio codecs.
Output frequency configuration for I2S in beagleboard? (underrun problem) -- ALSA Devel
This about describes the level of complexity you would be faced with. No rocket science, but nothing trivial either. Plus there is the wonderful alsa-devel mailing list where you can ask the board driver developers for help. If you are fine with this level of expertise, your project will most likely be successful. If not, I would not pursue this route.
Old 31st October 2011, 10:53 PM   #23
OK, i've had a decent look at that thread, and also found this post which explains the physical output. (4 data pins and 4 grounds, AFAICT).
When they are talking about the codec, i guess this is what is controlling the hardware that deals with outputting the I2S data from the audio stream etc? And this hardware is seen by the OS as a soundcard, right?
Looking round the post i linked and DAC schematic (+ related DAC datasheet), i have figured out what is going on with most of the pins.. but i'm not sure what the 'PD' pin would be, and idea?
Whilst i can't be certain since i haven't started looking at it from step 1-- and sure there will be some 'growing pains'-- I am relatively comfortable with that complexity. And definitely willing.
Are there any cheaper boards out yet with I2S output? (all i really need is I2S and USB2 out) And do literally all somewhat-modern DACs take I2S input?? IE if i go the I2S route i can be looking for what specific chip i want without having to worry about compatibilites etc.
Old 31st October 2011, 11:57 PM   #24
counter culture is offline counter culture  United States
Jeez...
LOOK AT THE LINK I POSTED!
... or don't.
Old 1st November 2011, 12:42 AM   #25
I did. It looks interesting...sorry i didn't comment on it, I was just exploring the options re: I2S. Do you not think I2S would allow for more (better?) options? I don't mind that its more work.
Old 1st November 2011, 12:58 AM   #26
verballydecapitating is offline verballydecapitating  New Zealand
Thanks for the link counter culture Looks like a good cheap branded usb DAC.. nice.
Old 1st November 2011, 02:05 AM   #27
I thought you were looking for a cheap plug-and-play solution with reasonable performance...
If you go with I2S yes, you have the option of building with a zillion chips, but as phofman says 'No rocket science, but nothing trivial either.' You can easily end up with degraded performance due to PCB layout or other factors if you're a novice.
In your position I'd buy the Behringer to have something to listen to, it's UKP22 from Amazon and I'd get a PCM1794 or what-have-you from TI as a sample (yes they'll give you one if you register, and a PCM2706 to recover I2S from USB) and mess around building it at my leisure (while listening to the Behringer).
@verdec No problemo.
Old 1st November 2011, 05:12 AM   #28
cogitech is offline cogitech  Canada
cogitech's Avatar
Originally Posted by Pano View Post
I was going to suggest the FiiO D3, but it does not have a USB input.
There are a lot of decent USB DACs based on the TI PCM27XX series. They sound quite good. Maybe something like the MUSE DA20. Have a look on eBay.
HotAudio.com (Dave) sells one based on the PCM 2705, called the DAC Destroyer, which goes for $70. I have not heard it myself because I own one of his DAC WOWs (which is fantastic), but lots of people seem to like the value the Destroyer offers. Dave's a great guy to deal with, too. He makes them all by hand and obviously takes great pride in his work.
Old 1st November 2011, 10:35 AM   #29
In this context codec means the integrated circuit - DAC, often combined with ADC. Usually the codec is controlled via I2C bus (or a similar serial protocol) which handles digital volume control, muting, pre-emphasis, etc. Take a look at some AKM datasheets.
The usual audio codecs accept I2S input format. There are codecs with Intel HD audio inputs (often from Realtek) but these are used on motherboards only. Again, take a look at the wide selection of AKM codecs, they have detailed datasheets online.
A sound card consists of two major parts:
1. Communication controller (PCI controller, USB device controller). On one side it communicates with the PCI (PCI bus, USB bus, PCI-e bus), on the other side it communicates with codecs (I2S for data + I2C for control, Intel HDA for data+control)
Example: Envy24 for PCI, PCM2706 for USB, integrated Intel HDA controlled in intel south bridge, etc.
2. One or several codecs (ADCs, DACs). If they provide some control functions and these functions are hooked to the communication controller, the driver can operate these functions via the controller (I2C, GPIOs, etc.)
Optionally there can be SPDIF transceivers (e.g. AK4113/4/7), DSP processors etc.
Power down?
Well, good to hear that But you have been warned :-)
This is an interesting page too Adding a new DAC - Ubicom Developer
I tried to google some brand new arm linux board under 100USD, to no avail. There is a used beagleboard on ebay. If you want to go this route, you might want to wait for RaspberryPi which should be really inexpensive.
Twitter
Old 1st November 2011, 01:06 PM   #30
@counter culture; thats a decent suggestion. Thanks for the info on the TI chips. I guess the PCM2706 isn't part of the samples program. If true, where should these be acquired? is ebay ok??
@phofman; ..powerdown sounds sensible. Yes the rasberryPi looks perfect, but its not out yet so.. 'don't count your chickens' type thing. I see there has JUST been a new board, the 'BeagleBone' released which is ~$88. Any idea if this has I2S out? i couldn't find any info about that yet, but otherwise fits the bill.
And hey, if you don't do things that are out of your comfort zone, you don't improve, right?
Decent affordable DAC for PC?Hide this!Advertise here!
Advice need: Wav/flac Reader with decent DAC Tony09 Digital Source 29 23rd August 2011 09:19 PM
Really!? - no decent diy DAC with basic 5.1/PCM functionality as well? Galgo Digital Line Level 26 26th June 2010 10:18 PM
PC crossover with IIR filters, affordable? thadman Multi-Way 9 19th April 2007 11:06 AM
Wanted: External, portable CD-ROM or DVD drive; decent USB DAC, portable speakers. Spasticteapot Swap Meet 0 31st May 2006 02:13 AM
decent pc soundcard with multiple outputs? zag0r Digital Source 6 10th May 2004 04:00 PM
