| PC Based Computer music servers, crossovers, and equalization |
#11 |
Hi Spot,
I've built some new amps and a problem has just come up with AC3 filter and its to do with bass redirection levels. When you are using a stereo input and use bass redirection to the sub, there is no way to adjust the level of the redirected bass. The subs level control only works when the input is a separate LFE channel. This has occured because of different amplifiers for the sub in relation to the other channels and the sub is far too loud. There are two work arounds for this:- 1) With the bass redirection box ticked, add some of the front channels (inverted) to the sub channels. I use -0.5L and -0.5R. 2) Add a line level control (potentiometer) to the input of the sub amp and adjust for the correct level with redirected bass. Adjust the levels of the bass within AC3 on 5.1 inputs when redirected bass is off. AC3 allows you to save your speaker settings, so I now call up the one required for whether the input is stereo or 5.1. Hope this helps in your setup. Cheers Ned |
#12 |
On a PC speaker (5.1 ch) like Logitech X540 is not possible because his pre'amp construction is wierd,the speakers gets signal from front L&R input not from SUB input,and LFE crossover has no efect on sub speaker.Also bass-redirection is wierd.
I have X-Fi Titanium Fat. Pro. and Xonar D1 audio card and act exactly the same,they have (booth card) bass redirection option,LFE freq. cutoff by driver software. Real AV Recivers (multichannels) are no dificulties with setings for sub. |
| PC based digital crossover with dolby digital live | preiter | PC Based | 64 | 25th April 2012 08:14 PM |
| PC-based server versus network-based player | hillbear | PC Based | 14 | 12th July 2011 12:13 AM |
| PC Crossover Software | Tenson | Multi-Way | 30 | 28th February 2011 04:26 PM |
| Looking for a New PC based Loudspeaker Crossover - What is available? | mikaljones21 | PC Based | 9 | 28th June 2010 02:53 PM |
| Music Server and PC based XO & EQ | otto88 | Multi-Way | 10 | 19th May 2010 01:41 PM |
| Page generated in 0.05463 seconds (81.12% PHP - 18.88% MySQL) with 10 queries |
