Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 29th November 2011, 07:11 PM   #71
Hi Koon
I always trying to build myself the dll with VST_SSEFIR.cpp source but now i have errors in building :
1>VST.obj : error LNK2019: symbole externe non résolu "public: virtual void __thiscall AudioEffect::canProcessReplacing(bool)
Do you know where is the problem ?
Old 29th November 2011, 08:24 PM   #72
Hi Mike, I will take a look tonight.
Old 30th November 2011, 02:56 AM   #73
Hi Mike
canProcessReplacing found in audioeffect.cpp
and,,,
#if VST_2_4_EXTENSIONS
canProcessReplacing (); // mandatory in VST 2.4!
cEffect.processDoubleReplacing = processClassDoubleReplacing;
#endif
So, please check your project has audioeffect.cpp and,
aeffect.h has
// VST Plug-Ins SDK
// Version 2.4 $Date: 2006/06/20 17:22:55 $
#ifndef VST_2_4_EXTENSIONS
#define VST_2_4_EXTENSIONS 1 ///< Version 2.4 extensions (01-01-2006)
#endif
if not, you are loading lower version VST SDK?
(VST, ASIO, too much confusing.. but some kind of standard)
Old 3rd December 2011, 08:20 PM   #74
Hi Koon,
audioeffect.cpp and aeffect.h dont have :
#endif
So does i have to add this ?
Old 3rd December 2011, 09:31 PM   #75
What is the version number on the head of aeffect.h?
maybe you have different version.
I'm using "vst_sdk2_4_rev2.zip"
do you have same one?
Old 4th December 2011, 01:39 PM   #76
Hi Koon
When i checked aeffect.h i mistaken , so lines :
#endif
are present in the file and version is :
// VST Plug-Ins SDK
The SDK fike is "vst_sdk2_4_rev2.zip"
Old 4th December 2011, 04:32 PM   #77
So you have 2.4 SDK, but your project can not find 2.4 SDK?
I think you also have 2.3 SDK and your project is looking it.
Maybe,
(1) remove 2.3 SDK. search audioeffect.h for whole PC, if found more than 1, duplicated.
(2) Check Visual Studio, Project, Property, VC directory.
I have "C:\VST\vst_sdk2_4_rev2\vstsdk2.4\pluginterfaces\v st2.x;$(IncludePath)"
And, Can you build sample VST, like adelay or again? This is important.
It shows how to build VST.
Then, you can use my source code to build yours.
Old 10th January 2012, 01:10 PM   #78
rvrazvan's Avatar
one question:
Can you time-allign drivers using Reaper?
Old 10th January 2012, 04:47 PM   #79
Originally Posted by rvrazvan View Post
one question:
Time-allign, means "delay"? yes, I can use delay VST.
Old 17th January 2012, 04:01 PM   #80
boris81 is offline boris81  United States
Hi KOON3876,
Thank you for sharing this groundbreaking work. It's very exciting to see FIR filters on Windows for free. However I don't feel that the VST platform is the best route for implementation. I'd much rather see a crossover done in the audio driver so all audio played on the computer will be processed before reaching the soundcard outputs. I looked into writing virtual audio drivers but the learning curve is very steep.
There's also another alternative that involves 2 sound cards and a standalone application doing the processing. Card1 will be designated as the default sound on the system. The physical output on Card1 will be looped back to the input on Card1 with a patch cable (preferably on the digital path to avoid unnecessary conversion to analog). Then a standalone program running on the PC will read the input from Card1, do the FIR processing and output the filtered signals on Card2's outputs. This way unprocessed data never reaches Card2's outputs.
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Foobar2000 FIR Crossover from Aedio tschanrm Digital Source 3 9th April 2006 09:14 PM
Room EQ notch filters with delay? MBK Multi-Way 9 1st October 2005 03:48 PM
Anyone using an FIR digital crossover? jazzius Digital Source 7 27th October 2003 03:34 PM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Copyright ©1999-2013 diyAudio
