AVX based FIR VST, crossover / EQ / DRC and delay - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 3rd November 2011, 06:01 PM   #41
Send a message via ICQ to cka3o4nuk
i see and tryied that way
but sometimes i need sound for video...
and so i need something for ds-asio bridge
so the video player just can se the virtual sound card
Old 3rd November 2011, 06:34 PM   #42
That is the Video Player's issue, (which has no ASIO support)
anyway I don't use VAC.
Some Video player should have ASIO support.
ASIO Window Media Player Plugin | Free software downloads at SourceForge.net
Old 3rd November 2011, 07:17 PM   #43
Thanx KOON ill try
Old 3rd November 2011, 07:19 PM   #44
i also plan later to set that xo to another pc (not the main one)
and dont use if for all staf exept music
so i plan in future make spdif-in active too. so i can just use the spdif out on the main pc
Old 5th November 2011, 07:41 PM   #45
Radian is offline Radian  Germany
Originally Posted by phofman View Post
Your route is doubtlessly the most elegant one but requires very deep knowledge of several technologies. IMO the most simple and least expensive way is to use any 7.1 card based on Envy24 (Revolution 7.1, Prodigy7.1, etc.) and tap the I2S lines of ICE1724. Multiple clock crystals, clock logic, PCI logic, drivers for all major OSes, datasheet, all is there ready to use and the price on ebay is negligible.
That's what I am doing at the moment.
Envy24HT I2S from the resistors next to the chip to AK4396 Dac board.
My other boards will arrive next week I hope. Then I will evaluate
the sound to my QA550 SD player. If this solution holds up, then three AK4396 boards will be connected.
I also got LVDS chips from TI to evaluate differecial I2S over a longer distance.
I will report back when I am done.
Klaus
Old 10th November 2011, 05:03 AM   #46
Originally Posted by jdubs View Post
KOON3876, nice work....this looks awesome!
How does this setup handle sample rate changes? I.e., going from 16/44.1 material to 24/192 material (.flac files) in Foobar?
-Jim
Hi Jim
Now I'm converting my own SACD to ISO format.
By foo_input_sacd, I can play it with 88.2 on sub small speaker.
So I need sample rate changes to be implemented. Now I'm testing.
Also I added one more parameter bar, to change TAPS 1024/2048/4096/8192.
After some test I will post new version.
maybe I can not use 8192TAPS/192/4Way until 2015.
Old 13th November 2011, 08:48 PM   #47
HI Koon
If you are planned to compile a new version of VST_SSEFIR , could you change the accuracy of the frequency parameter bar ?
Around 200 Hz , the other frequency available is only 160 or 240 Hz.
10 Hz accuracy at 200 hz will be more convenient ...
Jean Michel
Old 13th November 2011, 10:20 PM   #48
Mi Mike
I modified value-to-Freq routine,
more accurate. Please note that Filter curve = about 20dB/20Hz.
if (ret < 75.0f) return 70;
if (ret < 85.0f) return 80;
if (ret < 95.0f) return 90;
if (ret < 105.0f) return 100;
if (ret < 115.0f) return 110;
if (ret < 125.0f) return 120;
if (ret < 135.0f) return 130;
if (ret < 145.0f) return 140;
if (ret < 155.0f) return 150;
if (ret < 165.0f) return 160;
if (ret < 175.0f) return 170;
if (ret < 185.0f) return 180;
if (ret < 195.0f) return 190;
if (ret < 205.0f) return 200;
if (ret < 215.0f) return 210;
if (ret < 225.0f) return 220;
if (ret < 235.0f) return 230;
if (ret < 250.0f) return 240;
if (ret < 270.0f) return 260;
if (ret < 290.0f) return 280;
if (ret < 310.0f) return 300;
if (ret < 330.0f) return 320;
if (ret < 350.0f) return 340;
if (ret < 370.0f) return 360;
Old 13th November 2011, 11:12 PM   #49
Default Mac xo proof of concept
YouTube - Broadcast Yourself.
Old 14th November 2011, 04:30 PM   #50
Hi Koon,
Thanks you very much to have already wrote a new version of VST_SSEFIR !
But someting goes wrong, an error appears when im loading the plugin.
Jean Michel
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Foobar2000 FIR Crossover from Aedio tschanrm Digital Source 3 9th April 2006 09:14 PM
Room EQ notch filters with delay? MBK Multi-Way 9 1st October 2005 03:48 PM
Anyone using an FIR digital crossover? jazzius Digital Source 7 27th October 2003 03:34 PM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Copyright 1999-2017 diyAudio
