PC Based Computer music servers, crossovers, and equalization
AVX based FIR VST, crossover / EQ / DRC and delay
Old 29th October 2011, 10:17 PM   #31
phofman is offline phofman  Czech Republic
I know very little about PCI, but would not this The size limit of IO space in each BAR of a PCI card cause a problem with 4kB of PCI IO space, using the mentioned simple in/out calls?
Your solution would certainly work but I would not want to use it in a more demanding or more multitasking environment. The RT linux kernel is just soft realtime and having to refresh the card every 1ms regardless of the actual latency required sounds like a tough call to me.
Old 30th October 2011, 04:43 AM   #32
KOON3876 is offline KOON3876
===sorry still off topic===
Thanks phofman
”The RT linux kernel is just soft realtime”
oh. really? Then it will be hard to execute every msec.
should have large buffer, like IDT72V04 FIFO memory. (handling FIFO is much easy, than handling RAM from FPGA, and FIFO can be expanded)
and by using FIFO there are no limitation problem for I/O area address issue.
anyway, there is at least 1 way to build completely free / open digital sound card for Linux.
Old 31st October 2011, 09:41 PM   #33
cka3o4nuk is offline cka3o4nuk  Ukraine
Send a message via ICQ to cka3o4nuk
KOON3876
Thanx very much for your work
hope to test fir filters in this week
one more addon
you can use VAC(Virtual audio cable)
In order to use VST not only from foobar
from everything you what!
also for some tests just multichannel 7.1 sound card can be used as output device
Old 1st November 2011, 05:53 AM   #34
Hi VAC has it's own in/out asynchronous buffer, and can cause underrun/overrun.
Now I'm using foobar(ASIO) + Reaper as VST host (in, out both ASIO) + exaU2I (ASIO).
Old 1st November 2011, 06:40 AM   #35
So reaper can accept as a virtual card anything not only asio?
Old 1st November 2011, 11:58 AM   #36
No reaper can't be used as sound card and vac can
So I just add vac and for the system its totaly clear
Just a soundcard
Sent from my T959 using Tapatalk
Old 1st November 2011, 01:31 PM   #37
Koon once again thanx
Can you compile 2048 and 4096 tap version?
Thanx
Old 2nd November 2011, 12:50 AM   #38
jdubs is offline jdubs  United States
KOON3876, nice work....this looks awesome!
How does this setup handle sample rate changes? I.e., going from 16/44.1 material to 24/192 material (.flac files) in Foobar?
Also, has anyone tried the HDMI route, yet?
-Jim
Old 2nd November 2011, 02:48 AM   #39
Hi jdubs, sample rate to 192 will require 8192 Taps, for same accuracy (around 20Hz),
So processing goes x4(taps) x4(sampling) = 16 times heavy. I'm not sure it can work.
Please wait for next generation CPU
Old 3rd November 2011, 05:11 PM   #40
"As Sound Card"..?
Reaper has the component "ReaRoute", It looks like ASIO device from other player software.
and VST component can be connected to ReaRoute.
I posted how-to here.
https://sites.google.com/site/koonau...-FFT-crossover
AVX based FIR VST, crossover / EQ / DRC and delayHide this!Advertise here!
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Foobar2000 FIR Crossover from Aedio tschanrm Digital Source 3 9th April 2006 09:14 PM
Room EQ notch filters with delay? MBK Multi-Way 9 1st October 2005 03:48 PM
Anyone using an FIR digital crossover? jazzius Digital Source 7 27th October 2003 03:34 PM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
