| PC Based Computer music servers, crossovers, and equalization |
I am considering building something like Linkwitz's "Pluto" system, but with a twist. The powered speakers would in this case have built-in USB DACs and wireless usb hubs. These would end up plugged into a computer, which would "see" two stereo devices, each one per speaker.
This seems easy enough. Now I get to the crossover part. I would like to emulate the active crossover by using the computer to split the audio, apply filters, and redirect the audio to the separate USB devices. Now, the only software I have been able to find that MAY do this is LSPCAD Pro, which is $1100 and has WAY more functionality than is needed. The other way I could think of is some kind of solution using linux, pulseaudio, and multiple instances of a graphical EQ. But I'm a novice when it comes to these gritty aspects of digital audio. Does anyone have any suggestions on how to implement a "computer" crossover? For less than the price tag of lspcad? |
#2 |
just another
#3 |
How will you deal with the skew? USB is serial and one speaker will get it's samples before the other. The timing details are determined by the USB host and you have no control.
#4 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
It strikes me this is one case where you definitely do not want asynchronous USB. The skews for adaptive ('old technology') USB will just translate into relatively minor time delays (different buffer lengths perhaps) but with asynch USB you'd have two totally asynchronous clocks in the two USB DACs so there's in theory no bound to the skew.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#5 |
Async mode would require async reclocking in SW (libsamplerate) but that would wipe out the actual advantage of async USB.
I do not have any windows experience, but it is feasible to make it in linux, using brutefir. You can do the channel routing directly in alsa, no need to complicate it with pulseaudio. But be prepared to overcome a number of issues which would arise along the way, definitely not a project for an evening. BTW, the new USB drivers in linux alsa commited to GIT last month are capable of reporting the samples being currently transferred to the USB sound card down to 1ms precision. Last edited by phofman; 28th September 2011 at 06:51 AM. |
#6 |
Well, skew is not something I had thought about. The more I read up on what you guys have said, the more I am thinking that my idea, though neat, is beyond my skill level.
I still would like to build a Pluto-style system, though I may consider a non-diy alternative to the crossover (Behringer makes a digital xo I am thinking about). Not sure how else I would wirelessly transmit audio at 24/96. I may just have to build something more conventional. ![]() Thanks for the responses! Diyaudio rocks. |
#7 |
Sometimes a square peg fits a round hole just fine
couldnt you use a syncronous master clock? whats your budget? because you can use allocator a specific program for digital XO combined with a multichannel usb-i2s convertor like the exadevices unit
| Crossover for vifa 2 way setup - how can I find out what this crossover is doing? | Tino | Multi-Way | 11 | 17th May 2009 04:21 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Emulated Games on PC | Stocker | Everything Else | 0 | 22nd December 2005 01:31 PM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| About crossover | billy | Multi-Way | 14 | 25th July 2002 04:54 PM |
| Page generated in 0.09549 seconds (76.64% PHP - 23.36% MySQL) with 10 queries |
