Xonar ST/STX mods...
Yes, that caps are the final AC coupling caps. Better replacing it with non polar ones of an higher capacity value (10 -16v rated), and paralleled it with good film caps (1-2µ or more)
Thanks!
I actually had everything I needed already in my workshop.
So while I upgraded the card from Burson V6 to V7 (the Wima caps were already in), I replaced these with 220µF Nichicon ES, parallel with 1µF Jantzen Z-Cap and two 47nF Styroflex (I wanted to use 100nF but did not had them in stock) each.
That one of the caps is bent is on purpose so the card still fits with my network card next to it.
It sounds amazing!
That would just work if it is the old PCI card and has a desktop PC to connect.
If he uses the PCIe one and just has a notebook, he needs to look for a thunderbold PCIe dock.
Maybe there is something cheap to be found on Aliexpress bit on Amazon it would be one of the external graphics card boxes for 300$+
If you have something emitting, you should try to do something against the emitting.
For exaple desable WiFi (in the UEFI) or Similar.
Adding an EMI shield or moving the card to another slot or position (with a riser connector) would be also a good try.
I need 7 channels 😉 (and i can not see how people get along with 2 channels and passive crossovers).
And no, even if i could get along with a pure stereo dac, i wouldn't buy a already built device. I like it, when i can take influence on the devices i use, and make it as i need it.
Best regards
Jochen
It has been quite a few years I moved from PCI soundcard to usb DAC mostly because there was not enough room to apply any more modifications to Xonar STX. By the time I quit it was looking like this
A second PCB is attached underneath like a double slot PCI card, holding dedicated regulators for each chip on the soundcard involving cutting copper traces and the alike. I also converted the output to balanced passive I/V. I cut the RC filters on the opamps feedback network, and wired mini XLR. The I/V resistors were soldered on opamp sockets and allowed to test different values from as low as 2 ohm up to 100, 22 ohm being a nice compromise.
Ah ok. You might want to see if you can find an Essence STX II 7.1 with the daughtercard. It doesn't offer balanced outputs but it does have separate RCA outputs for all 8 channels which is quite a big improvement over 3.5mm stereo jacks. I went from the D2X to that and it was a pretty big improvement.
I used REW to do room correction with Equalizer APO.
