PC Based Computer music servers, crossovers, and equalization
Xonar ST/STX mods...
Old 28th March 2013, 08:31 AM   #291
Corvus5 is offline Corvus5  Poland
Corvus5's Avatar
Good measurements Coris. I already wanted to give you the idea of using oscilloscope thinking you've got the access to the academy lab gear and by your knowledge thinking you are the student. You might be able to try the Agilent impedance meter as I used to measure cable. This time you may find the proper capacitor setup and getting the whole measurement up to 110MHz like was in my case. All in a few seconds.
Have you noticed very high noise floor at 60dB? It may be due to oscilloscope resolution limit. I see you moved from 2V peak-peak to 23V at output. Was that true? That's a bit high. My record was ~10Vrms from the I/V opamps only.
You've got some HF noise but it's the limited sampling rate distortion. The generated signal might not be clear enough. Try the ARTA plus the Jitter test. You won't get any distortion from the sampling rate. But to measure jitter this way you've got to have much lower noise. Peaks are HF clock noise, smoothed base of the main singal is the LF noise of the clock.
If it sound good, then it's ok. Too bad we can't compare our cards. What was funny from my headphones is that the drivers acted like a window do the new room. Sounded like there was another room inside and at normal size ;-)
Old 28th March 2013, 08:38 AM   #292
Corvus5's Avatar
Originally Posted by hollowman View Post
Which cap are you talking about?
Some reg. designs use BOTH (small and large value) caps per their datasheet suggestions (if the above is for LM7805, are you using datasheet suggestions?). Parallel the two and listen/measure. Or try the default 0.33uF per Fairchild PDF.
You may see the description. The 7805 input cap. The datasheet shows only most common connection. For the audio application it has to be tuned. Paralleling tantalum and ceramic caps for audio? No. The resonance will kill the final sound. However I use such a connection in one place. Probably not for long.
Old 28th March 2013, 09:47 AM   #293
Coris is offline Coris  Norway
Coris's Avatar
The 2V scale I used for no signal measurement and HF noises. It were to low signal there to be seen something on 20V scale. I had to use 20V scale for output measurement, because the high level signal...
I have on final opamp power rails +/- 15V, so there is quite normal that is on output 24Vpp. I think is right like this. The NSR is very good over the connection cable (BTW, not even shielded cables...). It is lowered this high level output at right level on the other end (amp input) by an potentiometer. It give me a very good dynamic this way on an unbalanced amplifier...
It is very possible that the generated signal were not very good/accurate. I couldn't control that. Else I had to get in to the board, and I just thought is to much work to do it so. To digital generate a signal is not just the right way to do that, but anyway...
I have seen that HF noise I have is a square non recurrent signal. Quite good defined and very hard to synchronize it to. I do not know very well where it can come from. It may be just noises induced from somewhere in the computer...
To be honest, I do not want very much to work further and find in this area.
The resulted sound (as it is my board per today) is just amazing for an computer sound card.
I have an Oppo player (modified hardly too) which it use ESS9018 to play out the files. I can hardly hear the difference of how sounds those two devices: the modded sound card and the (modified) Oppo player. I expected actually to have a gap in the sound quality between those two devices, but is not at all... It may just be in this case a very high level of performances one can get out of an PCM1792 DAC.
I fully agree, and I experience the same about the sound out of my speakers, when using very high fidelity devices: the speakers become just transparent, it not actually exist, and it open like a big window through the sound space/scene.
Modding my Oppo player I have experienced even more in this sound field. Is only amazing how much and how high the sound details level can be encoded inside of a digital file (even mp3 encoded) when one have the possibility to use all that detailed informations to reproduce out (reconstruct) the sounds...
I appreciate from my part that I am at least finished with this Xonar STX chapter for now... I just see forward to another more exciting "chapters"...
Old 28th March 2013, 03:04 PM   #294
hollowman is offline hollowman  United States
hollowman's Avatar
Unusual for a major PC manuf., Asus seem to have some interest in the audiophile community. Hence, the Xonar with its decent (stock) parts choice and opamp modularity. The ESS9018 and/or dual-DAC arrangement (of ESS9018, 1792, etc) would not require too much redesign (i.e, R&D $$) to implement in future Xonars. Also firmware-based filters, such as Minimum-Phase, would be easy to incorporate w/o much re-design effort.
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 29th March 2013, 11:16 AM   #295
Corvus5's Avatar
Only the DAC Vcom was changed.
Old 29th March 2013, 12:07 PM   #296
Corvus5's Avatar
Here it's easier to see. With LF jitter the sound is flat with no depth. It's very close to the listener.
Old 29th March 2013, 01:00 PM   #297
androa76 is offline androa76  Slovenia
How did you changed-modified Vcom?
Old 29th March 2013, 01:22 PM   #298
Corvus5's Avatar
I minimized semi-HF jitter (+/-50Hz) later too. The Vcom caps are on the board, to the left of the DAC. The stock is AFAIR Nichicon Fine Gold 47uF 25V. The stock measure is not available. It depends on too many things. The datasheet says to use polarized 47uF caps for each channel. There are two caps, each for every channel. Someone may change only one of it and hear the difference between speakers. Right now I'm using low ESR ceramic cap from TDK - C2012, 10uF/10V for HF jitter reduction and AVX - TPSD tantalum cap 220uF/10V for LF jitter reduction.
Old 29th March 2013, 02:24 PM   #299
So if i understand you right, you have soldered 2 capacitors per Vcom rail.
Have you tried low leakage current capacitors bypassed with ceramics?
AVX Tantal 220uF/10v has CV of about 22uA and low leakage current capacitor like Nichicon KL 0,2uA.
If you will try that combination, can you also make measurement and put it here?
Have you tried LME49990 at buffer stage?... Try ... maybe you will be impresed.
I have heavilly tweaked dac with dsd1792 and LME49720 for I/V and LME49990 with gain 2, sounds most balanced and with lowest noise. AD797br oscillated...
Thank you if you do that measurement.
Old 29th March 2013, 02:55 PM   #300
Coris's Avatar
I assume there is about pins 21,22 of the DAC chip. I used there 300F/6V ceramics paralleled with 0,1 nF film... But it may work well with tantalum too.
1000/6V ceramics for decoupling on each analogue L/R stage of the DAC.
Xonar ST/STX mods...Hide this!Advertise here!
Issues Of Asus Xonar Essence Stx fotios Digital Line Level 3 13th March 2016 11:42 PM
XONAR STX e Vanguard TCXO: disappointment robyonekenoby PC Based 9 21st December 2014 08:39 AM
Xonar STX Op-amp change Rullknufs PC Based 10 24th September 2014 11:39 PM
New Asus Xonar Essence STX Drivers Brian Kingsbury PC Based 6 9th March 2011 09:52 AM
