Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 12th October 2011, 08:10 PM   #11
About to replace the RCA's, they started shorting out so just decided to replace them with some higher quality and more durable ones, might have to do some drilling to widened the ports a tad bit. They're CNC sliver plated got them for $10.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old 13th October 2011, 08:42 AM   #12
Coris is offline Coris  Norway
Hi Kuze
I can see in your picture that you have connected the oscillator power to the 12v rail of the card. That ferite bead you have connected it should have approx 10 - 11v on that place. This it could be quite wrong... I do not know how this can work for you... That oscillator it have to be feed it at 5v DC power... You should use the output of the 7805 regulator which is right beside the connection point you have used (that ferrite bead).
Else I`ve just removed any RCA connector from that place and soldered 10cm silver wires with BNC connector/plug on the end. Soldered directliy on the board output points. I`m satisfy with this work around... Is not so much place on that braket for a good mounting quality RCA connectors... And the body of the RCA connectors have to be isolated from that breaket...
Old 13th October 2011, 07:42 PM   #13
Referring to your last post and mine previous.
It is possible that I did not seen very well in your picture that place you connected the oscillator power pin to. My card is an STX, so is very possible that the arrangement of the components are different... But anyway, for be more clear in my explanation, I will post a picture here. Again, is about Xonar STX.
Old 13th October 2011, 09:54 PM   #14
Ok thanks, seen it done this way in another thread and everything seems just fine to me, however now you mention it i should double check with a multimeter just to make sure.
Also i don't plan on replacing any caps for now... not until i get a good soldering station, in your illustration you show some caps should be removed, should they be removed and be replaced or just removed completely?
Will it make a difference even though all the other caps are stock?
Old 14th October 2011, 06:42 AM   #15
The caps should be replaced! Will be a little problem to just remove all the caps from the board... They have to be there, but replaced with something better.
I will suggest you to first disconnect the oscillator power from that point, measure to ensure it is 5 V in that place and then solder back the oscillator. Else, if is there more than 5 v that Vanguard can be destroyed.
It is the best to do the mods one by one... You can chose the order, but I think this is better, than change all at once...
This picture you find it show a little of my solution about the RCA output. The caps you see as removed on that picture are soldered on the back side of the board.... But they still be there in place.
You welcome to ask any time before you will want to go forward to another mod. Will take the caps mod later when you will decide to do it.
Old 14th October 2011, 01:25 PM   #16
Let me clarify... It has been working for over a month with no problems soldered at the point shown in my picture, but just to be safe i moved it to the 5v you suggested and still works fine.
This is where i saw it done using that method: http://www.head-fi.org/t/421890/the-...ns-thread/1890
As for caps what do you recommend apart from ceramics?
Old 14th October 2011, 01:36 PM   #17
Is no any problem to take 5v from there, if you have it there. Is OK!
Else is no so much to be recommend about the ceramics... It works fine any kind of such cons....
Old 14th October 2011, 11:47 PM   #18
Hi Con, I have a bunch of questions to ask you as it seems as though you're the person to ask about this
Anyways here they are:
1. What model/size ferrite bead should be used next to the oscillator and how/where should it be mounted?
2. What type of glue should be used on the oscillator and approximately how much?
3. What wire should I use between the oscillator? Should it be insulated
4. What kind of solder should be used? I'm under the impression that 0.7mm solder is good for electronics but I'm unsure about everything else :P
5. What brand caps did you use? I have no idea which to chose from lol
Thank you very much in advance
Old 15th October 2011, 12:11 AM   #19
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I posted up my (very much more modest) mods to ST on Head-Fi here, if anyone's feeling less brave than Coris:
HELP! Need opinions for upgrading to Benchmark DAC1 HELP!
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 15th October 2011, 08:29 AM   #20
Hi
You did it very right at this "level" of mod! LM6172 is that I used my self with best result. Maybe you will try this op amp on the output/final stage too... If you will succeed to remove the sockets and solder the op amps directly on board, will much better. The easiest way to remove the socket is to destroy it (the plastic body). Cut carefully out all, pin by pin and care for do not touch the traces on the board, and have in good shape the rest of the sockets pins soldered in to the board. You will use those as soldering points for the new op amps. Do not try to de-solder on the board it self. The traces get destroyed at once!
Is very right that the feedback cap have to be quite few pF. The original feedback caps on the board are film caps. They do not like so much to be soldered and just dies when de-soldering it. The plastic film do not tolerate hot thing around...
With this mod done, I just suggest you to remove all the components just before the RCA connectors (see picture on few previous posts), and put only there, between the op amp output pin and the RCA centre, an non inductive (SMD) 10 ohm resistor, specially if you will have an LM6172 on the final stage. The SMD components is better to be soldered on the board, on the traces. They do not like at all any mechanical stress.
Then you can start to replace the original caps on the board (analogue stage first).
XONAR STX e Vanguard TCXO: disappointment robyonekenoby PC Based 8 29th April 2012 08:29 PM
Xonar STX Op-amp change Rullknufs PC Based 2 27th September 2011 06:24 AM
New Asus Xonar Essence STX Drivers Brian Kingsbury PC Based 6 9th March 2011 09:52 AM
Issues Of Asus Xonar Essence Stx fotios Digital Line Level 0 12th May 2009 09:42 PM
Copyright ©1999-2013 diyAudio
