How to tell if my usb 3.0 disk is 3.0 or 2.0? How to tell if my usb 3.0 disk is 3.0 or 2.0? - diyAudio
PC Based Computer music servers, crossovers, and equalization
Old 12th August 2011, 03:50 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default How to tell if my usb 3.0 disk is 3.0 or 2.0?
I connected a usb 3.0 hdd enclosure to my pc, yet it does not seem very fast. In copying 130 GB its going at about 26 MB/sec according to windows.
How do I tell if it is transferring data under usb 3.0 or under usb 2.0 protocols?
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 12th August 2011, 04:07 PM   #2
digits is offline digits
digits's Avatar
unless you have a usb3 motherboard it will just connect as 2.
Old 12th August 2011, 05:19 PM   #3
lgreen's Avatar
aaaahhh, yeah I have a motherboard with many usb 3 connections and plugged the usb 3 drive into the usb 3 slot, but since all of these connections are backwards compatible with usb 2.0 how do you actually confirm you are using usb 3 vs. usb 2 on this particular device?
Old 26th January 2013, 08:23 PM   #4
lgreen's Avatar
Ok, I will answer my own question, there are 2 things to check.
Go under control panel--->Hardware-->device manager and twirl down universal serial bus. Look for USB 3 or "super speed" controllers to make sure you have the right drivers.
Next hook up a fast disk like SSD into a USB 3.0 enclosure and run some disk benchmarks (crystalmark (sequential) or ATTO) to make sure you are getting over 35-40 MB/sec transfer rates ano if so you are actually using usb 3.0. If you don't have a SSD, even a normal SATA magnetic drive under usb 3.0 should give 70-100 MB/sec, proving usb 3.0 is active. Again, any I/O over 35 MB/sec means usb 3.0 is up and working.
Old 26th January 2013, 08:25 PM   #5
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Anti-virus software may be slowing the process.
Frank
How to tell if my usb 3.0 disk is 3.0 or 2.0?Hide this!Advertise here!
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 08:47 PM
Disk Clamping - Which is best ?? poynton Digital Source 32 1st January 2010 04:57 PM
Disk Needs Help Spinning delory Digital Source 4 14th September 2007 07:37 PM
Good Synthesizer Imitation (including Floppy Disk or USB Hookup) kamikazi_kostka Instruments and Amps 1 30th November 2006 03:19 PM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
Copyright ©1999-2017 diyAudio
