Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
PC Based Computer music servers, crossovers, and equalization |
#21 |
Hi phofman,
my point is, that -b 32 and hw:0,0 are *not* working currently! My aim with sox is not to do any conversion, just use the 24bit ADC and the 24bbit DAC in a loop (full duplex mode) Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#22 |
Try the recording with
Code:
arecord -v -f S24_3LE -c 2 -D plughw:0 input.wav |
#23 |
I'm on the road for a few days. I will try when I'm back home.
Rüdiger
#24 |
This is the output:
Code:
arecord -v -f S24_3LE -c 2 -D plughw:0 input.wav Aufnahme: WAVE 'input.wav' : Signed 24 bit Little Endian in 3bytes, Rate: 8000 Hz, stereo Plug PCM: Rate conversion PCM (44100, sformat=S32_LE) Converter: linear-interpolation Protocol version: 10002 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S24_3LE subformat : STD channels : 2 rate : 8000 exact rate : 8000 (8000/1) msbits : 24 buffer_size : 1486 period_size : 185 period_time : 23219 tstamp_mode : NONE period_step : 1 avail_min : 185 period_event : 0 start_threshold : 1 stop_threshold : 1486 silence_threshold: 0 silence_size : 0 boundary : 194772992 Slave: Hardware PCM card 0 'RME Digi96/8 PST' device 0 subdevice 0 Its setup is: stream : CAPTURE access : MMAP_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 44100 exact rate : 44100 (44100/1) msbits : 32 buffer_size : 8192 period_size : 1024 period_time : 23219 tstamp_mode : NONE period_step : 1 avail_min : 1024 period_event : 0 start_threshold : 6 stop_threshold : 8192 silence_threshold: 0 silence_size : 0 boundary : 1073741824 appl_ptr : 0 hw_ptr : 0 aplay states Code:
aplay input.wav Wiedergabe: WAVE 'input.wav' : Signed 24 bit Little Endian in 3bytes, Rate: 8000 Hz, stereo
#25 |
Very well, thanks for the outputs.
In the first case you told arecord to capture a 24bit stereo file. You did not specify the samplerate and arecord picked the default - 8000 Hz. The request went through the plug plugin (see the Plug PCM line) which matched your request with the card capabilities, as reported by its driver. The lowest rate your card supports is 44100. The plug plugin must provide a conversion from this rate to your requested 8000Hz. BTW your default resampling method is rather low quality (linear-interpolation), you may want to play with defaults.pcm.rate_converter , e.g. Advanced Linux Sound System user questions The card does not support native 24bits. Well, the actual ADC and DAC do, but the card PCI controller works at 32bits, as is the case with many cards. Therefore the plug must convert from 32bits to 24bits, your requested format. This produced your requested 8/24 file. Your second example plays this file back. Since you did not specify the actual device, the "default" was used. If you invoke aplay with the -v option (verbose), we will be able to see what the alsa-lib stack did with your request, just as we did with arecord -v. Without the verbose log we do not know how your default device is defined, whether it goes through pulseaudio, dmix, plain plughw, etc. |
#26 |
Okay:
Code:
aplay -v input.wav Wiedergabe: WAVE 'input.wav' : Signed 32 bit Little Endian, Rate: 8000 Hz, stereo Plug PCM: Rate conversion PCM (32000, sformat=S32_LE) Converter: linear-interpolation Protocol version: 10002 Its setup is: stream : PLAYBACK access : RW_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 8000 exact rate : 8000 (8000/1) msbits : 32 buffer_size : 2048 period_size : 256 period_time : 32000 tstamp_mode : NONE period_step : 1 avail_min : 256 period_event : 0 start_threshold : 2048 stop_threshold : 2048 silence_threshold: 0 silence_size : 0 boundary : 268435456 Slave: Hardware PCM card 0 'RME Digi96/8 PST' device 0 subdevice 0 Its setup is: stream : PLAYBACK access : MMAP_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 32000 exact rate : 32000 (32000/1) msbits : 32 buffer_size : 8192 period_size : 1024 period_time : 32000 tstamp_mode : NONE period_step : 1 avail_min : 1024 period_event : 0 start_threshold : 8192 stop_threshold : 8192 silence_threshold: 0 silence_size : 0 boundary : 1073741824 appl_ptr : 0 hw_ptr : 0 What I don't get from your explanation above: if my card interface reads 32bits nativly and the ADC/DAC work at 24bit, shouldn't the conversion not be done in hardware without any software drivers involved? (Since RME is proclaiming to even mix channels and so forth in hardware?) Rüdiger
#27 |
One issue seems to be:
arecord does not switch the card to other samplerates, rather uses sample rate conversion. Conversly, mpd switches the card to the desired sample rate. Look at the output if the card was running with 96k previously: Code:
arecord -v -f S32_LE -c 2 -r 96000-D hw:0,0 input.wav Aufnahme: WAVE 'hw:0,0' : Signed 32 bit Little Endian, Rate: 96000 Hz, stereo Plug PCM: Hardware PCM card 0 'RME Digi96/8 PST' device 0 subdevice 0 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 96000 exact rate : 96000 (96000/1) msbits : 32 buffer_size : 8192 period_size : 1024 period_time : 10666 tstamp_mode : NONE period_step : 1 avail_min : 1024 period_event : 0 start_threshold : 1 stop_threshold : 8192 silence_threshold: 0 silence_size : 0 boundary : 1073741824 appl_ptr : 0 hw_ptr : 0 Code:
# arecord -v -f S32_LE -c 2 -r 96000-D hw:0,0 input.wav Aufnahme: WAVE 'hw:0,0' : Signed 32 bit Little Endian, Rate: 96000 Hz, stereo Plug PCM: Rate conversion PCM (44100, sformat=S32_LE) Converter: linear-interpolation Protocol version: 10002 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 96000 exact rate : 96000 (96000/1) msbits : 32 buffer_size : 17832 period_size : 2229 period_time : 23219 tstamp_mode : NONE period_step : 1 avail_min : 2229 period_event : 0 start_threshold : 1 stop_threshold : 17832 silence_threshold: 0 silence_size : 0 boundary : 1168637952 Slave: Hardware PCM card 0 'RME Digi96/8 PST' device 0 subdevice 0 Its setup is: stream : CAPTURE access : MMAP_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 44100 exact rate : 44100 (44100/1) msbits : 32 buffer_size : 8192 period_size : 1024 period_time : 23219 tstamp_mode : NONE period_step : 1 avail_min : 1024 period_event : 0 start_threshold : 0 stop_threshold : 8192 silence_threshold: 0 silence_size : 0 boundary : 1073741824 appl_ptr : 0 hw_ptr : 0 EDIT: and I still don't get why the same card with the same OS does not work with hw:0,0 and sox anymore in another machine!
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog Last edited by Onvinyl; 16th October 2011 at 11:03 AM. |
#28 | ||
#29 | ||
And the "stuck" samplerate? Does not this particular soundcard support hardware mixing? If so, my guess is you left MPD running when trying your second arecord test. The card was switched to 44100 by MPD, the card was still open by MPD, as a result it was locked at 44100 and could not switch to 96000, you did not use hw:0 but the default via plug plugin (no space -D again), the plug plugin had to resample to the fixed samplerate of 44100. That is my guess, you can easily verify by making sure the device is not opened by any other process by running sudo lsof /dev/snd/* I would guess if you used hw:0 correctly, you would have received "Incorrect parameter" error as the samplerate would have been incompatible. Quote:
#30 | ||
Code:
arecord -v -f S32_LE -c 2 -r 96000 -D hw:0,0 input.wav Aufnahme: WAVE 'input.wav' : Signed 32 bit Little Endian, Rate: 96000 Hz, stereo Warnung: Rate ist nicht exakt (angefordert: 96000 Hz, unterstützt: 44100 Hz) probieren Sie bitte das plug-Plugin: Hardware PCM card 0 'RME Digi96/8 PST' device 0 subdevice 0 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S32_LE subformat : STD channels : 2 rate : 44100 exact rate : 44100 (44100/1) msbits : 32 buffer_size : 8192 period_size : 1024 period_time : 23219 tstamp_mode : NONE period_step : 1 avail_min : 1024 period_event : 0 start_threshold : 1 stop_threshold : 8192 silence_threshold: 0 silence_size : 0 boundary : 1073741824 appl_ptr : 0 hw_ptr : 0 Quote:
Code:
sox -b 32 -t alsa hw:0,0 -r 96000 -t alsa hw:0,0 (+some biquad commands) Code:
sox FAIL formats: can't open input `hw:0,0': select_format error: Operation not permitted Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog Last edited by Onvinyl; 16th October 2011 at 05:55 PM. |
Thread | Thread Starter | Forum | Replies | Last Post |
Anyone know an audio player that can do this? | Johnnz | Digital Source | 7 | 8th September 2009 07:13 AM |
AV IR over Cat5 (simple audio/video repeater for Sky, Digital Tv and Tape recorder) | audiodesign | Solid State | 0 | 24th June 2009 01:28 PM |
FS: Car audio fusing hardware | Rybaudio | Swap Meet | 0 | 11th July 2007 08:09 AM |
Laser Head Assemblies for Marantz DV7000 (DVD Player) & DR6000 (CD Recorder) | crdshark | Digital Source | 2 | 20th September 2004 11:40 AM |
Looking for a DVD-Audio player | wmeckle | Digital Source | 0 | 6th May 2003 02:04 PM |
New To Site? | Need Help? |
