PC Based Computer music servers, crossovers, and equalization
How do I rip a DTS encoded CD to multichannel flac?
Old 18th June 2011, 12:00 AM   #1
Clayton72 is offline Clayton72
Default How do I rip a DTS encoded CD to multichannel flac?
ello,
I have piles of DTS encoded 5.1 channel cd's. How can I rip those to multi-channel flac files, please?
I've already bought dbPowerAmp, so if that can be used somehow, that would be best.
Thanks,
Clayton
Old 18th June 2011, 06:06 PM   #2
frenzic is offline frenzic  Netherlands
You can use eac3to. See eac3to - audio conversion tool - Doom9's Forum.
Here's a quote from DTS 9624 decoding - SurroundSound | Google Groups
Joe A
View profile
Yup, you nailed it for the ones I had a problem with too...
I did try earlier pointing eac3to to the DVD structure (which it
didn't like), but feeding it the extracted DTS files with the Arcsoft
dshow components worked like a charm.
end quote
I did not read all of it but it seems to me you have to install Arcsoft dts decoder and do what Joe A did. That way you get WAVS in the original bit rate/sample rate and you do not have to worry about deltas. Then you can use dbpoweramp to make flacs and do tags.
Old 23rd June 2011, 09:23 PM   #3
That seems to be about DVD's. I can copy these CD's and they work just fine, but ripping to Flac and trying to play them back just results in noise that's not recognized as DTS needing to be decoded.
Old 25th June 2011, 12:18 AM   #4
That is because it is no longer DTS if you convert to flac and that is why you have to decode the DTS before you turn it into flac. Flac is not a container (like avi, mkv, vob), it is a codec, just like DTS (divx, x264, mpeg2). It does not matter if your source DTS stream is on a CD or on a DVD, it is all about the stream you need to decode.
Old 25th June 2011, 12:46 AM   #5
So is there a format I can rip to that would preserve the stream?
Old 25th June 2011, 07:55 PM   #6
Either you decode to multichannel WAV to have something in a format FLAC understands and does not add further compression or you extract the streams you need and save these as files. Ripping is something you do to copy media bit for bit, it is not the same as extracting streams from said media. That is demuxing. There is also the problem of delta's which you circumvent if you decode to lossless like WAV or FLAC. That way you can be sure 24/96 gets played that way and not at a crippled 48khz sample rate. If all else fails I'd fire up the old Foobar2000 and convert that way. But you do need the streams for that to work. Which container formats are you dealing with?
Old 5th July 2011, 06:49 PM   #7
I don't have software to decode the DTS signal. I'd love to jukebox the music, but my main goal is to archive the work a friend of mine so painstakingly did before passing away. Perhaps for now the simplest answer is to rip to ISO files that I can copy and secure.
Old 5th July 2011, 08:05 PM   #8
Yes backups are mandatory if you are serious about data. Anyway I found out it is possible to use the soft you bought to rip the DTS CD and in conjunction with a soft called wav2dts get playable files you can tag. From there all you need is foobar2000 which can convert anything to anything to get 5.1 lossless and maybe a 2channel version for CD. Foobar is free.
5.1 DTS Wav to FLAC [Archive] - Doom9's Forum
How do I rip a DTS encoded CD to multichannel flac?Hide this!Advertise here!
FLAC to CD player internal DAC Dyolf Digital Line Level 12 6th December 2010 12:48 PM
CD to FLAC Nikon1975 PC Based 16 25th May 2010 07:28 PM
What's the best method to rip CD to HDD? kop89 Digital Line Level 124 24th June 2009 05:56 AM
High quality CD-ROM drive for ripping to FLAC Tripmaster Digital Source 4 3rd August 2008 08:47 AM
CD Rip/SPDIF error rgrayton Digital Source 8 13th October 2006 05:47 PM
Copyright ©1999-2017 diyAudio
