Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 30th May 2011, 04:27 AM   #1
DQ828 is offline DQ828  Australia
DQ828's Avatar
Default Badly Ripped Music
Hi All
I wasn't exactly sure where to post this?
I was converted to the whole, rip you music collection and benefit from the convenience, with no loss of quality, and play it through a Squeezebox, but lately I have been wondering about the quality. More the ripping quality, than the playback quality of the components.
I ripped my collection with FLAC using Winamp, and have been adding CD's as they are purchased. I have had a couple of new CD's that once ripped, had some obvious sound defects that are not there when the CD is played. Also, when I have been playing the ripped music, I keep hearing the odd noise that I assumed was in the recording, but am now starting to wonder.
Does anyone have any thoughts on the phenomenon?
Old 30th May 2011, 06:49 AM   #2
Cant hear or notice any differences in my rips.
EAC and uncompressed WAV.
Thats my preference.
Plextor has (had ??) the name as 'the' drive to use for audio ripping/burning.
Not sure if thats still the case these days.
Old 30th May 2011, 08:16 AM   #3
wwenze is offline wwenze  Singapore
Will we also find programs that work on CD but don't when copied to HDD?
Jokes aside, use EAC with secure mode and rip at a low to medium speed and then verify it against others' rips via AccurateRip. High-speed ripping without error detection is prone to, well, errors.
Old 31st May 2011, 09:48 AM   #4
DQ828's Avatar
I tried a couple of rips with EAC & the AccurateRip couldn't verify the accuracy? Maybe it's my music tastes that are the problem.
I also wonder how they know what is an accurate rip?
Old 31st May 2011, 01:18 PM   #5
erin is offline erin  Australia
soundcheck's - audio@vise: CD Extraction
This blog entry very thoroughly goes through this topic. The findings may amaze you
Essential reading!
Old 31st May 2011, 01:54 PM   #6
That's an interesting find on Accurate Rip's issue, though if the same error exists with everybody and resulting in multiple identical rips done by different people this problem is more of aesthetics and less of functionality issue.
I'd like to point out that having the same checksum with multiple rips would only show the lack of random errors, but a consistent error like a bad burn for example will also result in all rips having the same checksum but containing the error. Hence the need for people to compare their rips.
Old 1st June 2011, 08:32 AM   #7
DQ828's Avatar
Hmm, as always there is contradictory information, thank you all for your input.
David
Old 1st June 2011, 10:40 AM   #8
SY's Avatar
David, how do you know that your issues are in the ripping rather than the playback?
EAC has worked perfectly for me, but it took some work to get playback right- I ended up having to change my OS and boot my computer differently to achieve reliable and accurate playback.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 2nd June 2011, 08:02 AM   #9
DQ828's Avatar
Every time I have played the music, the audible defects occured in the same sections & only in two tracks, I have since re-ripped those tracks & they are fine now.
It started me wondering how many very minor defects there could be in ripped music, so that they may effect the overall sound, but are not individually detectable by listening, I guess a bit like low level distortion, that may take the edge off the music but is hard to pin down. Before I posted this thread I was naive enough to think all rips where 100% & knew nothing of drive offsets.
Old 5th June 2011, 02:33 AM   #10
Wombat is offline Wombat  Germany
Wombat's Avatar
You shouldn´t worry to much about that "Offset" thing. It only may affect some milliseconds at the end or beginning of a song. If it doesn´t produce a clearly audible click or defect there you shouldn´t have a problem.
You may use CUETOOLS from Mr. Chudov over there CUETools - Hydrogenaudio Forums
It does verify your rips against AccurateRip Database without the need of having 100% set up EAC before.
If time permits - stuff some parsley in your ears and listen how it grows!
Much better ripped sound? otto88 PC Based 7 17th July 2010 04:21 PM
need help badly natz gangoso Solid State 4 23rd April 2004 06:52 AM
Page generated in 0.11114 seconds (79.71% PHP - 20.29% MySQL) with 10 queries
