Pure Player - Page 52 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 15th May 2014, 11:49 AM   #511
Just re opening this thread...
Did anyone ever play high res files, I've been toying around with some 24/96 and 24/192 files as I recently came across DSD/DXD files but was unable to play the latter in pure player...
There appears to be a plugin to play those files in foobar but I vastly prefer pure players SQ, so far the difference between 24 bit recording taken at 96 khz sample rate vs the same recording at 192 is large enough to make me investigate the even higher sample rates of the newer digital master format DSD/DXD
Have to add that I'm using a non oversampling DAC using a bunch of TDA 1543 converters which at best will do 15.99 bits at playback but the difference at the level of detail captured at the source makes a big difference...
Old 15th May 2014, 06:59 PM   #512
lduarte1973's Avatar
it plays 24/192 wav at least
Just because im getting bald doesnt mean i cant like hair metal
Old 9th June 2014, 08:03 AM   #513
Hi,is Pureplayer still for Download somewhere ?
Old 9th June 2014, 09:27 AM   #514
post 467
Old 9th June 2014, 03:31 PM   #515
I got it.Can i use pureplayer with Jplay?
Old 10th June 2014, 09:24 AM   #516
http://www.purediy.gr/downloads/pp.html
No, unfortunately it cannot be used along with Jplay.
Old 15th June 2014, 05:34 PM   #517
Smiley 09's Avatar
Lightbulb Wish List
Hello npetralias,
Originally Posted by npetralias View Post
I have read all the very positive comments on this thread and was also DL the file from the link You provide.
I inst. the PurePlayer as to per instr. on the web site, in the Win7 x64 - Ultra Lite (2,7 GB on Disc - Full Install + 32 GB RAM OnBoard)
Only the QuadroFX Graphics drivers loaded and Lynx22 Studio card ASIO audio drivers were loaded without any other Win BS loaded at all
- (In MB Bios were disabled: The Audio On Boar Interface, Printing Support, All Ethernet & WiFi Hardware Devices and none drivers installed either)
It is intend to be Only for HTPC Audio Playback from PC,
BUT...
The player starts and I'm able to insert The PCM only Audio files in the Play List window for playback
When I 2x press mouse over eg. the first file to be played back the mouse cursor change to time wait for start playback but after some 3 to 5 min of waiting the player is shut off by the system couse of no response.
All My PC Audio filez are DSD64, DSD128 & PCM 192 KHz -32-bit Floating point (IEEE) RF64 Format (4GB Plus Support)
The smallest file size i have is 5,52 GB in size.
Wish List for The Future Possible Upgrade:
1. ASIO 2xx Support - BitPerfect playBack possible?
2. Ability the PurePlayer will be able to PlayBack the PCM AudioFilez over 5GB & 192 KHz -32-bit Floating point (IEEE) RF64 Format (4GB Plus Support)
3. DSD64, DSD128 PlayBack possible ?
4. Inserting Multiple filez in to PlayList possible ?
5. Adding a PAUSE Button possible ?
6. A Thin horizontal RIBBON Track (3mm thick) to show a track progress (Time Lapse) to replace the Current thin 'Black' Separation Line between main playback commands and the Lover set of the Command Options ? (If not interfere with the PB)
For Yours Kind Answer Thank You in Advance,
Andreas G.
Old 16th June 2014, 07:35 AM   #518
Hello,
Pureplayer is a sequential memory player which means that before playback the software is buffering the entire file into RAM. Obviously is this very time consuming in your case (not efficient for big files). Obviously it does not fit your needs (> 5GB audio files). However you can debug by checking the "Show commands" button before "Play" and see the actual command that takes too long. You may load multiple files by using the "Load Dir" and "Load Tree" buttons or by simple "Drag and Drop".
Old 16th June 2014, 09:27 AM   #519
Smiley 09's Avatar
Hello,
Hello npetralias,
I do check the mem. usage and it is availl. 31.4GB of RAM so at least 5 full live concerts each 5GB+ file can easily fit into RAM, no limits, but when i check the Wasapi & Show command options and repeat the play a singe PCM 5,52 GB File it opens the command window for a half second and closed it immediately, & the pure player auto stops trying to play a file in the next 1-1/2 sec. What would be the cause for this ?
The only audio driver availl. to win7 is ASIO so maybe here is a problem ?
I Try the VLC Player with HiRes. option enabled and it plays the same audio file immediately.
Is there a fix for PurePlayer to use ASIO as well ?
I'd Really like to try PurePlayer and be able to enjoy its sound qualities as the other members reported in this thread.
Thank You for Yours Kind Answer,
Andreas
Old 16th June 2014, 09:31 AM   #520
phofman is offline phofman  Czech Republic
Is the pureplayer binary able/allowed to allocate that much of memory? 32bit vs. 64 bit etc...
Pure digital crossover cka3o4nuk Digital Line Level 14 12th September 2010 12:08 AM
Pure CD Player and DVD Transport Mechanism inside - what about this ?? tiefbassuebertr Digital Source 2 23rd February 2010 09:36 PM
Eminence Pure rossco Car Audio 2 28th March 2004 11:40 PM
Pure Delight Alain Dupont Pass Labs 107 8th February 2004 03:48 PM
Copyright 1999-2017 diyAudio
