PC Based Computer music servers, crossovers, and equalization
Pure Player
Pure Player
Old 10th July 2013, 07:34 AM   #461
lolo is offline lolo  France
lolo's Avatar
thanks and sorry for derailing the thread..
tried last night a couple of hours with another driver, it plays nicely but wasapi does not work with it (push wasapi ok on foobar, event wasapi not working).
Old 10th July 2013, 08:44 AM   #462
npetralias is offline npetralias  Greece
Yes, wasapi is not supported but the big deal here is ASIO. Try ASIO with foobar setting the lowest possible latency. I hope Pureplayer will support ASIO soon...
Old 10th July 2013, 08:54 AM   #463
lolo's Avatar
ok, will give it a try then. I shall also look to modify the DAC to take benefit of the I2S connection if I have time. but the next step is remove the trafo/coax and put a BNC instead.
thanks again for all your help!
Old 10th July 2013, 09:22 AM   #464
Yes this will probably have very good results but this interface has an output buffer chip and performs very well with coax too. Maybe it is better to go step by step.
Old 12th July 2013, 10:01 AM   #465
lolo's Avatar
ok, transformer removed, foobar-->ASIO. Works very well, at least on par with Hiface2.
Shame I can't use it with your player!!
Old 17th July 2013, 07:40 AM   #466
New version available here.
From this version on you may change the latency and buffersize parameters by editing pureplayer.ini file in order to optimize your system's playback performance (fine tuning based on your setup and ears). The benefits can be huge.
Old 17th July 2013, 08:53 PM   #467
lduarte1973 is offline lduarte1973  Portugal
Banned
doesnt work for me , flacplay error , i had to return to the older version
Old 18th July 2013, 05:44 AM   #468
Using wasapi or not?
Did you change the latency parameter?
Old 18th July 2013, 12:13 PM   #469
Banned
no wasapi and default latency , i had just installed it without changing anything
Old 18th July 2013, 12:18 PM   #470
Very strange, seems to be working for the others...
Pure PlayerHide this!Advertise here!
Pure digital crossover cka3o4nuk Digital Line Level 14 11th September 2010 11:08 PM
Pure CD Player and DVD Transport Mechanism inside - what about this ?? tiefbassuebertr Digital Source 2 23rd February 2010 08:36 PM
Eminence Pure rossco Car Audio 2 28th March 2004 10:40 PM
Pure Delight Alain Dupont Pass Labs 107 8th February 2004 02:48 PM
