| PC Based Computer music servers, crossovers, and equalization |
#401 |
@npetralias:
What are your suggestions regarding the optimal configuration for your player in a win 7-64 machine? What makes the purest sound, for example: asio or direct sound or wasapi? Soundcard or no soundcard at all? What are your experiences? Luki |
#402 | |
The best you can do is to use SSD hard disks for both OS and music, disable Virtual Memory, disable your Soundcard (if using a DAC), set Wasapi to "ON" (i know...sorry...), minimize the running processes-services and make a linear regulated Power Supply for you PC. This last thing may be a bit difficult for a Desktop PC but it is very easy for a netbook (an LM338K is usually enough). You may also check again Wasapi after changing the sampling rate in Control Panel\Hardware and Sound\Sound\Playback device\Properties\Advanced. Last edited by npetralias; 28th February 2013 at 12:34 PM. |
#403 |
No success. Whatever sample rate I choose, no sound. This is kind of frustrating, but on the other hand, the sound without Wasapi is so great, I´m wondering, what unknown bliss is coming if....
Luki |
#404 |
I can't hear the difference between Wasapi and non-Wasapi with this player.
(( Per |
#405 |
Yes, the difference in most cases is very small.
#406 | |
#407 |
#408 | |
#409 | |
Yor DAC arrived and the problem you mention occured. After installing Teralink drivers everything are just fine. Teralink 64bit driver, http://hifimediy.com/wp-content/uplo...64Bitdrive.rar Teralink 32bit driver, http://hifimediy.com/wp-content/uplo...a_20100401.zip Great DAC, by the way (after a 50 hrs burn in)...actually even better after installing some caps and a linear regulated 5V psu. ps. A new version is available with minor changes (track name display etc) http://www.purediy.gr/downloads/pp.html Last edited by npetralias; 16th March 2013 at 08:19 AM. |
#410 |
Thanks Nick..works as a charm!
| Pure digital crossover | cka3o4nuk | Digital Line Level | 14 | 11th September 2010 11:08 PM |
| Pure CD Player and DVD Transport Mechanism inside - what about this ?? | tiefbassuebertr | Digital Source | 2 | 23rd February 2010 08:36 PM |
| Eminence Pure | rossco | Car Audio | 2 | 28th March 2004 10:40 PM |
| Pure Delight | Alain Dupont | Pass Labs | 107 | 8th February 2004 02:48 PM |
