| PC Based Computer music servers, crossovers, and equalization |
#391 |
Sorry if you already wrote it and I did not notice: Do you get output when you play those files with another player that uses wasapi?
#392 |
No problem, I was able to play music with J Rivers set to Wasapi or Wasapi event. Please note that I am not person who is experiencing this problem. I suspect PP may set buffer size too small or large when Wasapi is turned ON. Also note that my system latency is very low when playing music, less than 500mS most of the time.
#393 |
further testings, I like the player more than Foobar. Better reverberation retrieval, and less center projection, the latter being very noticable, I can play much louder without strain. Well done again!
#394 |
Pureplayer is superior to Foobar which I stopped using sometimes ago.
#395 |
this is the best player i used so far , when they add windows file association to wav/mp3/cda it will be just perfect
Hey ! just because i´m going bald doesnt mean i cant like hair metal |
#396 |
npetralias,
Are still looking into solving the problem I mentioned earlier, or you still cannot duplicate it? If so then you do not intend to fix right, pity it is a very good piece of software and it is FREE. |
#397 | |
I am trying to find a computer to replicate the problem but until now everyone works OK... I will keep trying... |
#398 |
#399 |
#400 |
I use a number of DAC, the Chinese Matrix Cube based on Wolfson chipset, and also lately this cheap DAC based on ES9023 chipset, from HIFImeDIY.com costs me $59(model:UAE+), you should try this DAC it is excellent value for money, sounds very good.
Both these DACs I experienced the same problem. They don't use drivers that comes with the DAC but rather drivers inherent/embedded in Windows 7. |
| Pure digital crossover | cka3o4nuk | Digital Line Level | 14 | 11th September 2010 11:08 PM |
| Pure CD Player and DVD Transport Mechanism inside - what about this ?? | tiefbassuebertr | Digital Source | 2 | 23rd February 2010 08:36 PM |
| Eminence Pure | rossco | Car Audio | 2 | 28th March 2004 10:40 PM |
| Pure Delight | Alain Dupont | Pass Labs | 107 | 8th February 2004 02:48 PM |
