Pure Player - Page 24 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 6th July 2011, 11:11 AM   #231
It seems I am not the only one getting this 'skipping' problem with v2.7. It is pretty consistent - I load a single file or folder/playlist and get the problem. With a single track it will start playing OK, then after a few seconds it starts to go out-of-synch and echoes. With a list of tracks, it skips 1 or 2 tracks completely before it starts playing and then does the same. Same on flac and mp3. Same on 24/96 as 16/44. Load files up locally on HDD or from NAS !! Same files perfectly OK on Foobar/JRiver. Tried re-installing software - no good. Occasionally it does play perfectly OK and sounds really good, so I want to persist with it. Any bright ideas ???
Old 6th July 2011, 11:35 AM   #232
I 've heard of this problem (simultaneous playback) from others too, but i can't simulate it to none of my pc's. I am listening with PurePlayer daily and it never heppened. Do you have any desktop visual effects enabled?
Old 6th July 2011, 04:26 PM   #233
Hi, I am big fan of JRiver, but PP sounds better to me - more natural and organic. Well done with your work on it. However, this 'simultaneous playback' problem ! I use XP SP2 - virtual memory disabled - loads spare RAM - CPU hardly being used - no other apps running - no internet connection - monitor powered off - I have tried files on local HDD / USB stick / NAS all the same result. Tried single file / folders/ playlists - can't think of anything else to try. Have more or less identical setup on a friends PC, and it's fine, so I'm suspecting it may be my machine. Anything else to try before I start swapping bits of hardware or reintalling OS ?! BTW - I'm going to WIN7 soon so I'll report back. Many thanks
Old 6th July 2011, 06:01 PM   #234
jkeny is offline jkeny  Ireland
Banned
Hillbear, I get the same issue on a Win 7 setup - I haven't reported it here as my WIN 7 is a beta SP1 version & so I thought it might be a beta OS problem.
It seems to start multiple instances of flacplayer in the background & sometimes when I quit PP it still plays as Flacplayer is still playing in the background. Hope this helps in diagnosing the problem?
Old 6th July 2011, 08:58 PM   #235
It does the same with mp3 files as well as flac ! Same with 24/96. Also, it takes ages to start playing each track - possibly about 20-30 seconds. Will keep trying things...
Old 6th July 2011, 09:12 PM   #236
Banned
Yes, I've been trying it again & have noted a couple of things (I mostly play Flac or WAV files). No visual effects enabled.
- it seems to only happen when Wasapi is ticked on
- it seems to be caused by 24/96 or 24/88 files
- if it starts to skip, then turning off Waspi seems to bring it back & it begins to work properly again.
Old 6th July 2011, 10:10 PM   #237
Hi John - trying mp3 files. If I tick WASAPI box it skips through the whole list without playing them. If I then untick the box it starts playing track for 5 seconds or so...then starts 'double playing'. Same with FLAC and WAV, I'm afraid
Old 7th July 2011, 02:28 AM   #238
panord is offline panord  United States
I just installed version 1.2 and it played fine, without playing multiple files at once. I have not tried the various other versions besides 2.7 (which did play multiple files at once). I am using Win7 on an Acer netbook, so I know I'm using the bare minimum of memory, but I am running with many of the Windows components turned off, no anti-virus, no firewall and file paging turned off. I really haven't had a problem with other players (except for J.River in WASAPI Exclusive). I don't see how it could be the machine, unless there is some service or component turned off that is needed by PurePlayer.
Old 7th July 2011, 03:11 AM   #239
My simultaneous playback problem but not always happen, just sometimes. And i notices it only happen to music files with almost same filenames with different extention ( example 01mysong.mp3 with 011mysamplesong.flac ), but not always happen, just sometimes. I'm using windowsxp sp3, with standard visual themes. I always forgot to tick show command, howto make it always show command (for debugging purpose)?
Old 7th July 2011, 08:27 AM   #240
I made some changes, trying to fix this problem.
You may download version 2.7.1 here http://www.purediy.gr/downloads/pureplayer.zip
Cheers
Pure digital crossover cka3o4nuk Digital Line Level 14 12th September 2010 12:08 AM
Pure CD Player and DVD Transport Mechanism inside - what about this ?? tiefbassuebertr Digital Source 2 23rd February 2010 09:36 PM
Eminence Pure rossco Car Audio 2 28th March 2004 11:40 PM
Pure Delight Alain Dupont Pass Labs 107 8th February 2004 03:48 PM
Copyright 1999-2017 diyAudio
