| PC Based Computer music servers, crossovers, and equalization |
Is it the case that HDMI allows a source to send 8 channels of high def PCM?
So a PC with a modern video card (or a suitable Asus Xonar) could use an HT receiver as an 8 channel DAC and power amp system? I don't have a suitable card at the moment but systems like the Asrock Vision3D and boards like the Gigabyte E350N - both of which claim HDMI 1.4 - are interesting. How easy is it to drive these channels from a non-video app (not too bothered if its Win7 or Linux for this)? James |
#2 |
Banned
Yes, there are cards, drivers, HT receivers and audio software. Windows Media Player 9 supported 7.1, it's up to version 11. GA player claims 8 track.
I haven't tried it or seen it work, I'd be interested to hear from anybody who has. What material do you intend to play? w |
#3 |
Sometimes a square peg fits a round hole just fine
there is even a diy board for use with i2s and dxd input dacs. its designed for the ackodac 8 channel sabre dac, but outputs i2s, so dont see why it wouldnt work with other hardware that supports i2s input and multiple channels. supports many other formats too via hdmi
#4 | |
James . |
#5 |
Isn't HDMI encrypted?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
I *think* that (HDCP - is that what you mean?) is at the discretion of the source. But I could be wrong. The Xonar audio card seems to offer 8-channel ASIo on HDCP 1.3 - and I'm wondering if in fact the newer graphics cards which support HDMI 1.4 offer a similar level of access to the data channels.
Possibly I should sniff around in Linux audio channels, but I thought maybe someone here would know. |
#7 |
Typically , but it doesn't have to be. My 1080P divx's are bootleg non-encrypted w/7.1 lossless codec. They already have a blu-ray ripper in certain circles that bypasses HDCP . HDMI 1.3 is backwards compatible to any previous version or even a non-encrypted stream.
If I do play a native Blue-ray , my processor and memory use increase drastically to protect the "content". OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#8 | |
Banned
Your software would require to read an existing .wav file, process the information to extract bass, middle and treble information (and possibly a subwoofer track or tracks) and write out a set of mono files. You would then present these to the combiner, which would produce a file playable with WMP9 and above. If you care to dig into the 7.1 format, possibly doing some reverse-engineering, you can probably do the whole process in a single application without resorting to the combiner. I haven't dug into it that far but the original .wav header is not very complex, I thought it defaulted to stereo, I could be wrong, but I'm just answering from memory. Obviously this is not the same as doing the conversion on-the-fly, and it results in files as much as 4 times the size of the originals, but it is quite straightforward, with the exception perhaps of writing the filters, and it should work no problem. A little application that would allow you to pick the crossover frequencies and write out the result would probably find some users, I might write one myself, although it can't be long before a few start to appear. w |
#9 |
Not sure about ASIO drivers, but I can confirm that XBMC running under Linux was able to put out multichannel audio over HDMI on an Acer Revo (Nvidia ION platform). I believe that HDMI audio under Linux should be pretty well supported if you choose your hardware carefully.
#10 | |
| Laptop HDMI Output and DAC HDMI I2S Input. Can I get this going? | mikone | Digital Source | 1 | 7th September 2010 11:36 PM |
| 8 channel LPCM over HDMI, It's Multi Amp for Everyone | KOON3876 | Digital Line Level | 125 | 19th August 2010 08:00 PM |
| Decoding audio from HDMI | wasssup1990 | Digital Source | 2 | 19th July 2010 04:39 AM |
| Will TI Rescue DIY HD-Audio from Intel's HDMI/HDCP | cowboy99 | PC Based | 7 | 18th July 2010 12:04 PM |
| Page generated in 0.10116 seconds (89.27% PHP - 10.73% MySQL) with 10 queries |
