PC Based Computer music servers, crossovers, and equalization
Is anyone using DRC?
Old 22nd February 2011, 08:11 AM   #11
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
Originally Posted by dlsonic View Post
Hello,
I am currently using a SB touch with a qnap ts-219 nas. I would like to add a drc plugin. chaimovitch have you find a way to implement drc working with your squeezebox server on your nas ?
I'm pretty sure that your Qnap will run out of steam...
Old 25th February 2011, 10:40 PM   #12
JZatopa is offline JZatopa  United States
Thanks for the input guys. I think I am going to put off trying DRC again until there is a much simpler and efficient way of implementing it.
Old 27th February 2011, 06:23 AM   #13
AllenB is offline AllenB  Australia
I am new to DRC and I have tried to get it to work only under the room schroeder frequency, which failed and increased the high frequency content.
Is my DRC trying to make up for the lack of high frequency content in the impulse measurement and can I do anything about this?
Old 1st March 2011, 11:50 AM   #14
Mark_A_W is offline Mark_A_W  Australia
I have DRC working for 2 channel 44.1khz bit all the way to 8 channel 96khz, at 16 and 24 bits.
All without fiddling.
It is documented here:
http://www.diyaudio.com/forums/multi...ml#post2358684
Old 30th April 2011, 07:01 AM   #15
chaimovitch is offline chaimovitch  Australia
Default my studio
If you talk about your studio as your reference. I'm wondering if you run DRC also at your studio. How do you make sure that your mix is not "colored" by your studio-gear and studio itself?
[/QUOTE]
Because 'my studio' is actually the actual venue. I record on location that is 'my studio' is most often a church, a cathedral, a school auditorium etc.
Chaimovitch
Old 30th April 2011, 07:02 AM   #16
Hello,
Unfortunately not. Sorry
Old 15th July 2011, 03:19 PM   #17
Onvinyl is online now Onvinyl
Onvinyl's Avatar
Hi, I'm having troubles installing drc. Even with the most basic CFLAG settings, I get:
Code:
jamballa source # make install
install drc lsconv glsweep /usr/local/bin
install -d /usr/local/share/drc/config/
install config/* /usr/local/share/drc/config/
install: Verzeichnis ‚config/44.1 KHz‚ ausgelassen
install: Verzeichnis ‚config/48.0 KHz‚ ausgelassen
install: Verzeichnis ‚config/88.2 KHz‚ ausgelassen
install: Verzeichnis ‚config/96.0 KHz‚ ausgelassen
make: *** [install] Fehler 1
(the message reads "install: skipping directory 'config/*KHz' make: ***[install] error 1")
Any hints what to try?
RŁdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 15th July 2011, 11:31 PM   #18
You don't install DRC. You run it from a command line, with the appropriate parameters - usually from a batch file.
Old 16th July 2011, 06:10 AM   #19
Onvinyl's Avatar
Well, I have to build it from source, 'install' might be an inappropriate term, still, some files are being dispatched somewhere to the abyss of the systems' directory tree.
RŁdiger
Old 16th July 2011, 06:20 AM   #20
Linux...next you'll have to compile your damn soundcard driver..
The windows version is already compiled. It's a tricky enough process as it is.
I just can't see how linux is worth the pain. I've tried Ubuntu twice and gone back to Windows. Linux just has a way of making simple things impossible.
Is anyone using DRC?Hide this!Advertise here!
Drc Gui Jaco Pastorius Multi-Way 5 27th April 2009 03:19 PM
Measurement in DRC hajame Digital Line Level 2 10th September 2008 03:46 PM
A 'how to' for a PCXO and DRC ShinOBIWAN Multi-Way 0 3rd January 2006 08:43 PM
Start with DRC FaZ72 Digital Source 2 2nd May 2004 03:39 AM
DRC with that DRC thingy! 5th element Multi-Way 4 4th April 2004 03:46 PM
Copyright ©1999-2017 diyAudio
