| PC Based Computer music servers, crossovers, and equalization |
#41 |
Without a decent DAC there is little reason for Pure Music. Playback will be improved, but the improvement may be masked by the limiting quality of the Mac's internal DAC and even more the analog headphone output circuitry.
#42 |
Thanks Steve; just as I suspected. Home renovations prevent me from using a "real" audio system probably for another two months, and my job involves travel for extended periods of time in remote areas, where no hifi will be following me, and they could call me anytime.
I'll revisit the idea when it's more relevant to my audio needs. Hopefully that will be before next fall, but in reality it could be that long.
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..." |
#43 |
is choosing a less facetious title...
is anyone using the crossover facility? how well does it work/sound?
#44 |
frugal-phile(tm)
I plan to try it out with my Twin Alpair7, Quad SDX7 project (postponed until arrival of next batch of A7)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#45 |
i'll be trying it with the exa usb interface and dual ackodacs, amps initially a alephjx and a panson chip/mos amp. driven initially by a g5, but probably with a new mac mini and scanspeak 2 ways
#46 |
frugal-phile(tm)
I've a 4 channel Firewire DAC and a 20" G5 iMac.
dave
#47 |
have you tried it at all? does the g5 cope ok with the calculations for 4 channel?
#48 |
Passive Aggressive
Oliver
I am strictly WIN7. Is there any way to use MAC software on WIN7? If not, or if there would be no benefit even if I could.. do you have a preferred WIN solution. Wont pollute MAC based thread with more WIN7 stuff, but wondering what you thought. I just got a DAC and have been using J.River. Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#49 |
not politcally affiliated
Uriah,
If you get a mac-mini you can run windows, either in a virtual machine or natively in it's own partition. J-River is not bad, but seems to discover only half my music.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#50 | |
frugal-phile(tm)
dave
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 5 | 13th October 2012 05:18 AM |
| The New Yaqin/Music Angel/Meng & Others Discussion Thread | woodsart | Tubes / Valves | 15 | 21st September 2010 01:16 AM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
