Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 3rd October 2011, 09:02 PM   #41
b_force is offline b_force  Netherlands
Does someone know how to get Allocator working with Windows Media Centre (MCE 2005) or otherwise with ffdshow?
I'm planning to use my HTPC as DSP/crossover.
Unfortunately I can't find any solution that works with MCE 2005 (or Win7 instead)
I don't want to use foobar/winamp etc.
There are few laws more precise than those of perfect molecular chaos
Old 5th October 2011, 04:57 AM   #42
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Originally Posted by _henry_ View Post
how about apogee ensemble? its a complete package.
but its $2000
cheers
henry
Henry,
Thank you for the suggestion. So far I made my choice with the following set up: MacMini running Pure Audio. Pure Audio has included very good crossover and host AU filters as well. From there I am using USB to I2S converter and from there to dual Acko DACs. Passive I/V - Twisted Pair Legato, than to balanced jFet buffer with Lundahl transformer between I/V and buffer. This whole contraption from USB to amp is still under construction, but when is finished it will be IT.
www.burningamp.com
October 1, 2011
Old 5th October 2011, 05:34 AM   #43
AR2,
wow, thats alot of gear. is it Pure Audio or Pure Music?
i have so much interest with this 6moons audio reviews: Spatial
i can only think of the ultimate solution will be the signal from the computer treat as pure digital, and process it with ensemble or prism then goes to the amp.
but i could be wrong, since i only understand half of your setup )
cheers
henry
Old 5th October 2011, 05:49 AM   #44
Master Burner
AR2's Avatar
AR2,
cheers
henry
Yes you are correct, it is Pure Music. I checked on Spatial. It is essentially the same thing I am doing just packaged together with some other features. I use different programs to achieve the same - measurement.
Here is the link about my project still under construction.
Babelfishing by Mighty AR2
www.burningamp.com
October 1, 2011
Old 5th October 2011, 06:04 AM   #45
wow,
thats impressive. i hope u updated the progress, i think your system qualified as the
ULTIMATE DIGITAL STEREO SYSTEM. :d
cheers
henry
Old 24th October 2011, 03:41 PM   #46
Originally Posted by Radian View Post
If you can find one, Bluegears B-enspirer is the card to have for this purpose.
24/196. 4X AKM 4396. An external dac below $2000 will not work any better if
the signal is tapped after the dacs. Just a good coupling cap and all is fine.
I know this sounds like ** but thats what I experienced with that card. Modded
of course.A few TeddyRegs will work wonders.
Greets,
Klaus
Hi Klaus
Checking if the Bluegears B-enspirer = Club 3D Theatron (Agrippa?) DTS 7.1 = Auzentech X-Plosion 7.1 DTS Connect.
Saw your pics of mods, looks great.
And saw your posts on the Thuneau Forum a while back; did you get the Allocator to work or are you using (if any) different crossover software?
Regards, Finn
Old 26th October 2011, 08:14 AM   #47
Radian is offline Radian  Germany
Originally Posted by Finnogangela View Post
Hi Klaus
Regards, Finn
Sorry Finn for the late reply. I actually saw your post just by chance.
The b-enspirer and the equivilent Club3D card is not sold anymore.
If you find one used you need to look for Club3D Theatron DTS not the Agrippa.
I have killed my card a while back and that was it with the software crossover project.
The one thing with these cards was the AK4396 Dacs they used.
An extrnal Dac will not work any better if the signals are just
tapped after the dac chip.
What bothered me was the fact that these cards had just one simple passive
clock for the CMI chip. All the clocking was done internally.
At the moment I am revisiting the PC Crossover thing again.
This time by an Envy24HT card. I just tap the I2S signals after the Envy chip
on the resistors. From there I will use LVDS transmission to my three AK4396
Dac boards. I will report back once I got it completed.
Theoretically, there should not be a sonic disadvantage using a PCI card over a USB like the Exa device.
Cheap too, as I only payed 16 Euro for a used Hercules Fortissimo4
Greets,
Klaus
Old 27th October 2011, 08:34 AM   #48
Hi Klaus - no problem; with regards to dac-chips and data transfer I believe time is working for us :-)
Yeah, think I sorted out the different AK4396 cards; though not modable the Agrippa should be worth a try (over i.e onboard audio).
Would love to hear more specially about your I2S extraction and transfer to the the Dac boards; saw your participation on the DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 thread . I hope youŽll reveal hov you make the dac boards, omitting the unnecessary extraŽs found in the available kits.
Do you still plan on using the Allocator?
Regards, Finn
Need help choosing op amp for active crossovers and preamp Jonathan Z Solid State 20 31st August 2010 11:49 PM
choosing inductors for crossovers ark Multi-Way 12 9th March 2007 11:10 AM
Any soft to use a 5.1 soundcard as an active filter ?? youyoung21147 Digital Source 0 5th February 2006 08:20 AM
Active XO using PC soundcard? mr_push_pull Multi-Way 9 1st December 2005 06:31 PM
active crossover from a pc soundcard? bser Digital Source 17 18th August 2005 03:19 PM
Page generated in 0.11783 seconds (82.36% PHP - 17.64% MySQL) with 11 queries
