| PC Based Computer music servers, crossovers, and equalization |
I have been ripping cds to 44100/16 bit flac files for my PC with Asus Xonar Essence and am thinking that I should convert these files to 44100/24bit flac, which should be basically lossless, so that the digital volume control has enough bits to work on without causing significant rounding errors.
The PC is running Ubuntu 10.10 and 100% volume causes distortion Anyone with any thoughts about this? |
#2 |
The volume control is provided by digital circuits of the DAC chip in your sound card. It operates on the same data length regardless of the input audio file format - lower-precision formats have lower bits padded with zeros in the driver.
#3 |
You won't be 'converting' anything to 24 bit. The information just isn't encoded on the original CD to do that. You'll be guessing the intermediate values - that's all.
#4 |
Agreed that I cannot add resolution. I am thinking that the card is capable of 24 bit (20 bit in practice) resolution, so if I set the volume to about 0.7 to avoid distortions, I don't want the OS software multiplying a 16 bit value by some constant and truncating to 16 bit again.
A -60dB sinewave is already horribly quantised in 16 bit format. If the card actually is working as 24 bit, then no problem as this waveform will be fairly accurately scaled. Isn't the volume control implemented in the main cpu, not in the DAC these days? |
#5 | ||
#6 |
First of all, isn't this card running in 32 bit? Anyways i don't think your bit rate is the problem...
Most low-end equipment will distort even before the 0dbfs limit. Thats why mastering engineers often export their mixes a -0.5dbfs. So pushing your card's output over that threshold is probably causing the problem. Second of all, i don't understand why you need to set the output so loud! I never tryed to put my volume that loud cause is was afraid to kill my headphones. (Im using the beyerdynamics DT 770 pro 80Ohms. Good headphone listening level is around -20dbfs. And if you need higher volume in the speakers, put the volume up on the amp. I hope this helps! -Max |
#7 |
There was a time when it was the high end CD players with custom dsp filters that overloaded at 0dbfs.
Unfortunately many of my recent CD clip to full scale |
| Using 20 bit data with a pair of old 16 Bit DAC | stefanobilliani | Digital Source | 15 | 14th January 2007 12:55 AM |
| 24 bit I2S source to 16 bit DAC? | chris719 | Digital Source | 5 | 18th June 2005 05:24 PM |
| I2S 16 vs. 24 bit as in PCM 1792 data sheet? | capslock | Digital Source | 4 | 23rd September 2003 10:02 AM |
| Are DVD audio D/A's 16 or 24 bit? | Circlotron | Digital Source | 4 | 6th September 2002 12:04 AM |
| use digital attenuation to improve 16-bit CD playback on 24 bit DAC | capslock | Digital Source | 7 | 8th April 2002 11:18 PM |
| Page generated in 0.09577 seconds (78.51% PHP - 21.49% MySQL) with 10 queries |
