PC Based Computer music servers, crossovers, and equalization
Sound card or DAC upgrade on tight budget
Old 9th October 2010, 02:13 PM   #21
vann is offline vann  Macedonia
vann's Avatar
Originally Posted by nightanole View Post
Until you hook it up to an amp/preamp that has the inputs floating at 2.5 volts (most tripath class T amps, and others that are buffered with an opamp).
Meaning that in this case it could be better to protect the dac with some caps even if there is no dc offset to get rid off?
Sorry to bother with so many questions, I work in IT business and audio&electonics is a hobby to whom I have only recently payed more attention... there's much I don't understand.
Here's Amp9 form 41Hz I'm building:
*Top view.
- Left signal inputs, mute input and status outputs
- Top left input capacitors, Tripath TAA4100A chip
- Center left output filter toroid inductors, above them, close-up power capacitors
- Lower edge: Speaker outputs
- Right center: bulk power supply capacitors
- Right: power connector.
*Bottom view
- Bottom, Tripath TAA4100A chip with decoupling caps. Above them clamping diodes.
- Center top output filter capacitors
- Upper edge: Speaker outputs
- Right top: rectifier
Old 9th October 2010, 03:49 PM   #22
nightanole is offline nightanole  United States
So your amp is cap coupled. That means do what ever you want. Your safe. The caps protect your speakers, not your amp or dac. If there is dc offset, that means your speakers will be constantly sucked in or sucked out while the system is on.
Have fun winding the output coils of the amp, i know it took me over an hour.
PS: why are you building a 4 channel amp and 2 channel dac? You can only parallel that amp, you cant bridge it.
Old 9th October 2010, 04:04 PM   #23
vann's Avatar
Winding the toroids was actually kinda fun... I did 1-2 at a time during meetings at my workplace. Older colleagues with electronics experience didn't miss the chance to make fun out of my winding skills...
Kinda relaxing, first one or two came out not too good but on latter ones progress could be seen... shame I didn't had enough wire to rewind them. Voltmeter didn't showed much difference between any of the coils though.
It's a four channel amp since it will also double as a HT setup. (Tuba THT sub is also in making. Will use separate sub amp for that, courtesy of Jack Hidley)
Old 9th October 2010, 04:09 PM   #24
vann's Avatar
And about dac being 2 channel, I would only use it for music...
HT usage can be serviced with sound card outputs... I'm not so concerned about HT reproduction quality.
Old 1st November 2010, 11:43 AM   #25
theresa is offline theresa  United States
Default Asus Xonar Essence STX
I have the Xonar Essence and use it to listen to with my Sennheiser HD600s. It certainly is much better sounding than the onboard Realtek 889a. HD600s require a lot of power. Creative has had a monopoly and for that reason are not the best sounding nor suitable with power hungry 'phones according to others accounts and testing. Of course a separate headphone amp will probably provide plenty of power.
Sound card or DAC upgrade on tight budgetHide this!Advertise here!
What do i need? a DAC? CD Player? HQ Sound Card? rg12 Digital Source 25 16th September 2010 03:36 PM
Which DAC / External Sound Card from this list? rg12 Digital Source 0 5th September 2010 10:26 PM
Convert sound card to external DAC Zdman Digital Line Level 0 17th November 2008 02:01 PM
DAC/ Sound card argonrepublic Digital Source 0 11th July 2005 03:39 AM
DIY Amplifier Suggestions - on a tight budget elizard Chip Amps 103 16th July 2003 04:00 PM
