PC Based Computer music servers, crossovers, and equalization
USB to 7.1 24-bit 192KHz sound
Old 12th April 2013, 04:58 PM   #41
rsowen is offline rsowen  United Kingdom
This tool measures DPC latency, not audio latency through the driver/device, this is what I thought you were referring to.
Old 12th April 2013, 05:35 PM   #42
deanoUK is offline deanoUK  United Kingdom
If the DPC latency is too high you will not be able to set the audio latency
low without drop outs.
Using the MiniDSP USBStreamer (set for Maximum latency) I was getting audio drop out driving 4 I2S channels at 192Khz using a desktop PC with Q8300 processor.
I is also worth noting that most microphones drop off at around 20-22khz
so there is little point in recording at higher than 48k.
Dropping from 192k to 48k also greatly reduces the CPU load.
Old 13th April 2013, 02:51 AM   #43
Rixsta is offline Rixsta  United Kingdom
Originally Posted by deanoUK View Post
Also you will not get low latency with the XMOS/Thesycon solutions.
You also need to confirm that your CPU can "keep up".
Something like this RME: Hammerfall DSP Multiface II
at around 540 will work straight out of the box and may prove cheaper in the long run.
Thanks, The RME am thinking about and was originaly thinking of actualy just buying this xmos Reference
It is actualy most important to me that there are no dropouts in sound, the actual latency issue where a track is recorder slightly out of time when are overdubbing over a previous track is not a problem as i should be able to adjust with software.
I think your right tho before buying something like that it would be good to know that this laptop can handle it!
the RME's usualy have DSP on too and take the load of CPU as far as I Know
www.rikibuckingham.com...
Old 13th April 2013, 02:55 AM   #44
I am assuming you own a laptop or desktop PC ?
If so try this DPC Latency Checker
Post the results.
I will explain more later when I finish work.
Result : Some device drivers on this machine behave bad and will probably cause drop-outs in real-time audio and/or video streams.
48k and 24bit seem my usual standard realy, so that Xmos link I put Seems pretty good. also can imagine using its outputs to Tri-Amp.
Thanks for the help/input
Old 13th April 2013, 02:34 PM   #45
I have just remembered why I did not try the XMOS eval board.
I believe it comes with evaluation drivers that beep every now and again.
Please check with XMOS.
I would like to know the outcome.
Old 13th April 2013, 03:57 PM   #46
Cheers Ive sent them an email, looks like on the main page for it it says they are evaluation drivers but dosen't mention the beep, but they probably wouldn't lol
Well i got all Exited yesterday about the Roland R-26 as it said 6-channel recording in a small portable recorder and right they are it is, I had to look in the manual though to get to what i wanted
As a USB interface it can only record 2 of those channels to the Computer.
Oh well, I thought that recorder was it then!
May still buy it for band recordings though.
USB to 7.1 24-bit 192KHz soundHide this!Advertise here!
M2TECH Hiface USB->SPDIF 24/192Khz asynch Valeriano Digital Source 384 5th September 2012 07:05 PM
24 bit/192khz digital bcherry DIY HiFi Supply 11 2nd April 2010 05:03 AM
Looking for best -current- 192khz/24 bit outboard ADC for PC KBK Digital Source 17 22nd October 2009 01:06 AM
24 bit/192Khz spdif ? ashok Digital Source 30 10th October 2006 03:47 PM
24 bit 192khz s/cards 5th element Digital Source 12 11th September 2003 01:27 AM
