USB to 7.1 24-bit 192KHz sound - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 28th July 2010, 12:01 PM   #21
anbello is offline anbello  Italy
anbello's Avatar
Originally Posted by phofman View Post
What motivation do they have? You have given them money anyway.
Just to clarify:
i use MS OS only at work, at home and in particular for my media server/player i use only Linux, i would like to see MS UAC2 driver so that this technology can gain momentum.
Anyway what you say is true.
Ciao
Andrea
Old 28th July 2010, 02:28 PM   #22
phofman is offline phofman  Czech Republic
Unfortunately there are many technologies which never got momentum due to MS being less agile, such as virtual desktops.
Old 28th July 2010, 07:54 PM   #23
Originally Posted by anbello View Post
Thanks for the infos nyc_paramedic, now i would like to see products with more accessible price, i think when the UAC2 will became more supported on all the major OS (i don't understand why MS have no UAC2 driver till now) we will see UAC2 adapter and DAC with price near the actual UAC1 corrispective.
I am very enthusiastic about recently acquiring the Ayre DAC, but not because of it's 176/192 capability. I really admire what it does with 16bit/44.1 and some of the 24bit/96khz material I have --all USB Audio Class 1 technology.
I found out I was getting a UAC2 board in my Ayre *after* I had paid (black color is special order) for the DAC.
I spent my free afternoon yesterday listening to my DAC with only 16bit material. Music that I enjoy *and* is well recorded. If it's done right at 16/44.1, you'll need a very revealing system *and* have to listen closely to discern differences.
There's also plethora of good 24bit/96khz material out there and you don't need UAC2 or custom drivers to enjoy it.
P.S. One of my favorite albums, engineered by Steve Albini, is Nina Nastasia's [i]Dogs[i/]. Link: Dogs (album) - Wikipedia, the free encyclopedia
On Amazon's used marketplace cheap: http://www.amazon.com/Dogs-Nina-Nastasia/dp/B00023B1H6
Old 29th July 2010, 09:40 AM   #24
anbello's Avatar
On Amazon's used marketplace cheap: Amazon.com: Dogs: Nina Nastasia: Music
Hi nyc_paramedic,
i agree with you that is difficult to discerne from a good 44.1/16 and higher sampling frequencies/bit depth and anyway it is possible only with a really good system.
It is also true that you can do 96/24 with UAC1 but i would like to realize a multiway system with digital crossover an this is only possible with UAC2 interface because UAC1 at 96/24 has only one stereo channel.
Anyway there are other factor to prefer UAC2 over UAC1 as a better management of clocks and clock domains, the possibility to include a SRC unit (that if well implemented could be of help) and many other (i have read through the specifics too fast).
Another thing to think about the use of higher sampling frequencies/bit depth is that modern DAC have better numbers if feeded so.
Ciao
Andrea
Old 6th August 2010, 09:00 AM   #25
qusp is offline qusp  Australia
qusp's Avatar
how about the newish crystal semi chips? the CS4207 and dev board CD84207 with dev platform datasheet here
It uses the HD AUDIO codec, (or spdif input) has drivers for mac, windows and linux. 24/192 with 4 channels in, 6 channels out (maybe use 2 as custom device for 12 channels out dont know if you can do that in windows, easy in mac and linux)
even has an integrated headphone amp integrated ADC @ 24/96. The specs arent up to the standard of the highest end dacs out there, but are still pretty good and functionality is off the charts. you can buy the chip at digikey as well as the dev board.
i'm surprised I havent seen that much here about it. has integrated DSP for EQ also
Old 6th August 2010, 09:15 AM   #26
qusp's Avatar
ahh actually only 4 channels lineout per device and 2 channel headamp, has 2 x spdif outputs as well (so no reason you couldnt chain 2 together), spdif reciever, SRC etc. power packed little chip. been looking for an excuse to get the dev board for a while now, figure i'll finish whats on my plate first. By then maybe they'll have a professional full power version with even more functionality and maybe better DNR with current outputs perhaps, rather than the internal IV in this one
Old 15th August 2010, 10:37 PM   #27
on the subject of USB and Windows drivers - my AV amp uses a TUSB3200A USB chip, and allows input of 8 channels of USB audio at 48khz/16bit
question is though Windows just detects it as a "standard USB audio device"
I'm pretty sure the USB chip supports Aynchronous Sync Streaming- question is though - how do you set it to that mode - and how do you know what mode you're syncing at anyway ?
Old 16th August 2010, 07:27 AM   #28
According to the datasheet, the USB chip supports USB audio asynchronous, i.e. the firmware (8052 code) can disable the internal adaptive clock and use precise external clock. The question is whether that particular firmware in your AVR supports the asynchronous mode. I very doubt it since it is more complicated than adaptive and very few manufacturers have allocated the resources to develop it.
Old 5th April 2013, 08:36 PM   #29
Rixsta is offline Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Is there a DIY project that supports this around ? or any 4 to 8 channel recording or higher Diy Project ?
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 9th April 2013, 10:37 AM   #30
rsowen is offline rsowen  United Kingdom
I demonstrated this a couple of years ago on an XMOS device at NAMM.
Source was a bluray rip playing in VLC (on a Mac - so no 3rd party drivers required)
I did have to make some modifications to VLC since the Mac 7.1 audio support wasn't quite there... presumably because no one had used it before.
I keep meaning to dig these out and push them back to VLC..
M2TECH Hiface USB->SPDIF 24/192Khz asynch Valeriano Digital Source 384 5th September 2012 07:05 PM
24 bit/192khz digital bcherry DIY HiFi Supply 11 2nd April 2010 05:03 AM
Looking for best -current- 192khz/24 bit outboard ADC for PC KBK Digital Source 17 22nd October 2009 01:06 AM
24 bit/192Khz spdif ? ashok Digital Source 30 10th October 2006 03:47 PM
24 bit 192khz s/cards 5th element Digital Source 12 11th September 2003 01:27 AM
Copyright 1999-2017 diyAudio
