PC Based Computer music servers, crossovers, and equalization
Fast playback after replacing oscillator of X-Fi
Old 15th July 2010, 08:41 PM   #1
terranigma is offline terranigma
terranigma's Avatar
Default Fast playback after replacing oscillator of X-Fi
I replaced 24.576mhz crystal of X-Fi Prelude soundcard with an discrete oscillator with same value. But playback became much faster after this mod. Any suggestions please?
Old 15th July 2010, 10:25 PM   #2
kipman725 is offline kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Mesure both oscillators and determine the difference.
Old 15th July 2010, 10:42 PM   #3
terranigma's Avatar
Sorry, I have no measurement facility. I tried another two leg crystal it's ok.. but with another four-leg type of oscillator which I sure that is working, faster playback again.. I think there is a reason for using ordinary two-leg types of crystals with these cards.
Old 16th July 2010, 09:14 AM   #4
phofman is offline phofman  Czech Republic
Perhaps the chip runs at half the frequency of the crystal nominal value? I know crystals can run at multiples (harmonics), but I am not sure about fractions.
Old 16th July 2010, 11:06 AM   #5
terranigma's Avatar
Your direction gave me an idea..
I measured playback time vs. actual time, then i realize that there is exact 1/4 delay. Then actual clock must be 4/3 of 24.576, which means 18.432 mhz.. Now I have to find a oscillator to try with this value.
Old 16th July 2010, 11:49 AM   #6
sandyK is offline sandyK  Australia
The required oscillator frequency is 24.576MHZ, the same as the Xtal that you removed.
Download the data sheet for the DIR9001, and have a look at fig.9.
It should be fairly similar to what you have. You could also try a series resistor of 47-100 ohms in series with the output of your new oscillator.
SandyK
Old 16th July 2010, 12:33 PM   #7
terranigma's Avatar
SandyK
That is what i have done exactly.. I have used 24.576mhz oscillator. Also tried 100ohm resistor in series but it scratched the playback completely. If you sure that i have to use 24.576mhz, then have you any idea of exact 1/4 delay?
Old 16th July 2010, 12:49 PM   #8
terranigma
Sorry, but I do not know what is causing your problem. Perhaps the waveform isn't correct, or it is of incorrect amplitude? It seems to be a pretty standard type of oscillator input as used with many different I.C.s.
I recently replaced a simple xtal oscillator as shown in the DIR9001 data sheet with a 3.3V 24.576MHZ oscillator module in a DAC without any problems.
SandyK
Old 16th July 2010, 03:13 PM   #9
SoNic_real_one is offline SoNic_real_one  United States
To me that happens if I select bitmatched playback and I forget to change in Windows the 48kHz samplerate to 44.1kHz. Don't know why there are not in sync when bitmatched is selected (but they are sync'ed when I force the sound card on a certain samplerate). But the speed difference is then 48/44.1...
The value of 24.576MHz seems correct since it is 512 multiple of 48kHz (256 of 96kHz), and that's the native samplerates of X-Fi.
Old 16th July 2010, 06:49 PM   #10
terranigma's Avatar
Yes..that was it. Since i'm using ASIO as output, samplerate and masterclock varies dynamically. Weird thing that in my setup, if you ever play a 44100 track, there was no fallback for normal operation even you play a 48k track. You have to reboot. I just added SoX resampler to DSP list and everything seems fine..
Thank you all.
Fast playback after replacing oscillator of X-FiHide this!Advertise here!
Use of a Ribidum Oscillator as refrence oscillator in a DAC Mark A. Gulbrandsen Digital Line Level 19 2nd November 2014 02:35 AM
Playback Amp jman 31 Chip Amps 83 3rd May 2009 11:54 PM
Slow playback after replacing crystal on soundcard terranigma Digital Source 19 18th May 2008 01:23 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
