PC Based Computer music servers, crossovers, and equalization
Firewire 400 -vs- USB2.0 external harddrive
Old 1st July 2010, 04:08 PM   #1
Fsatsil is offline Fsatsil  United States
Default Firewire 400 -vs- USB2.0 external harddrive
Firewire 400 or USB 2.0 what do you guys prefer for an external hard drive? The drive would be used strictly for storage of my audio and video files.
Old 1st July 2010, 06:34 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Firewire. No contest.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st July 2010, 06:42 PM   #3
doug20 is offline doug20  United States
Why is it a no contest? USB 2.0 is the standard connection. Firewire is not a universal standard.
There is no real speed difference here so what specs do you look?
Personally, i would go with a Sata array storage.
Old 1st July 2010, 06:56 PM   #4
frugal-phile(tm)
planet10's Avatar
There is a real speed difference. Firewire has its own controller hardware & is specifically designed for media. USB 2 uses CPU for control.
As to standard, every single one of my computers has Firewire.
Sata is defintly more direct route, but not as common for external devices.
dave
Old 1st July 2010, 09:56 PM   #5
Thanks,
I assuming CPUs have more then enough powerand I have done the tests between all 3 connection types. None of the connection types are "Too slow" to be used. The data speed of standard firewire and USB 2.0
I have 3 TBs of movies, 40Gig of music. I have a 2 HTPC and a music server that I distribute throughout my house (7 rooms).
USB had no issues at all with music or movie playback but obviously I can not do RAID with it.
I would simply comment that all proper storage/backup designs are important here and I would pick eSata.
The OP only wants storage and if the firewire choice costs more then he shouldn't bother with it.
Old 2nd July 2010, 04:07 PM   #6
How does ethernet compare to firewire, usb, esata...etc?
Old 3rd July 2010, 10:32 PM   #7
BrianVG is offline BrianVG  Belgium
USB 3.0>Firewire 3200>Firewire 800> USB 2.0>Firewire 400> USB 1.1
Firewire can deliver up to 70Watts of power for your devices so you won't need an external power supply in most cases. USB 2.0 will be replaced by 3.0 VERY SOON. The only problem is that 3.0 is so fast that your harddrives read/writes slower then the dataflow so at this stage 3.0 is only a littlebit faster than Firewire 800.
USB 1.0 1,5 Mbit/s 0,19 MB/s
USB 1.1 12 Mbit/s 1,5 MB/s
USB 2.0 480 Mbit/s 60 MB/s
USB 3.0 4,8 Gbit/s 600 MB/s
FireWire 400 400 Mbit/s 50 MB/s
FireWire 800 800 Mbit/s 100 MB/s
FireWire 3200 3,2 Gbit/s 400 MB/s
Got this table from wikipedia
Old 4th July 2010, 01:11 AM   #8
frugal-phile(tm)
planet10's Avatar
In real world tests done by the tech guy around here, FireWire 400 was ~25-30% faster than USB 2.
As in everything one needs to understand the gotchas.
dave
Old 4th July 2010, 01:31 AM   #9
infinia is offline infinia  United States
infinia's Avatar
Either OR Why not get an ext HDD with both. Very common maybe $10 more, then you can decide for yourself.
Old 6th July 2010, 08:39 PM   #10
I prefer also prefer Firewire(800). The fact that it's able to give power to my drives is was the key for me.
Firewire 400 -vs- USB2.0 external harddriveHide this!Advertise here!
USB2.0 vs 3.0 for SPDIF conversion Salsero Digital Source 0 14th January 2010 11:50 PM
Firewire 400 6 pin on any Notebook/Laptops? Hearinspace Digital Line Level 0 13th September 2008 01:47 AM
Building a PSU for an external firewire soundcard fosforo Power Supplies 5 4th May 2007 09:17 PM
FS: SCSI harddrive Tekko Swap Meet 9 19th February 2006 09:10 AM
How big Harddrive can I use with my motherboard? Christian Digital Source 44 5th August 2003 07:03 AM
