PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 3rd November 2012, 06:22 PM   #801
entrenous is offline entrenous
thanks. i'm not sure i hear any difference (i do not even see it enabled at -s; should it be there?). - anyway, i thinks logitech should put you on a payroll instead of killing the product line!
p.s. could you please direct me to the info how to donate you /can not find on your blog/...
Old 5th November 2012, 05:43 AM   #802
MurphyUHF10 is offline MurphyUHF10  Australia
MurphyUHF10's Avatar
Originally Posted by soundcheck View Post
It's just more convenient to me to keep a quick access option via screen - just in case. And then, the cables/connectors are that flimsy that the chance you break em sooner or later are quite realistic.
Ok, I understand.. Make sense to me ;-)
Thanks!
CM
Old 15th November 2012, 05:21 AM   #803
Hi Guys,
I'm trying the "tt -b 4000" command.. it seems to execute correctly and the sbt re-boots ok.. But when I "tt -s" the buffer still shows 20000..
Any ideas..??
Thanks!
CM
Old 15th November 2012, 06:25 AM   #804
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
Originally Posted by MurphyUHF10 View Post
Hi Guys,
Any ideas..??
Thanks!
CM
EDO mixup.
Old 15th November 2012, 11:06 AM   #805
Hmm.. Yes, I have EDO installed.. How did you gues??
It was installed before TT v3.0,, but it doesnt show up as an app in "installed apps" so I dont know how to un-install it..??
Btw; cant TT and EDO co-exist..?? I'm using coax, but would like to use USB down the track...
Hey, nice job with TT, and also with the info on your blog pages!!
Ta
CM
Old 15th November 2012, 11:56 AM   #806
soundcheck's Avatar
Lucky guess.
EDO and TT got some overlaps (touching the same files). You stepped on one of them.
Old 16th November 2012, 01:00 AM   #807
Hmm,, ok.. Thanks for that!
Like I said, I cant work out how to remove EDO,, So I will need to perform a factory re-set on my SBT,, and start all over..
Firstly however, I will trawl through this thread to see if the Buffer size is one of the main beneifts.. Otherwis it may be eaiser to leave it at 20000
Ta
CM
Old 16th November 2012, 08:18 AM   #808
soundcheck's Avatar
Yep. You won't get around it.
You'll find several different opinions about its impact. I think there is no
question that it has an impact.
Some like it better small, some prefer a large BS. Large BS gets it IMO mellower (on my system) . Some call it more natural.
Small BS gets it more dynamic and IMO resolution increases.
Too small will cause XRUNS. A very small BS might sound a bit aggressive/edgy.
I find it very interesting that certain people reported not being able to get
lower then 4000 or even a little higher to avoid running into XRUNS.
Another person reported his prefered rate at 3450 ( if I recall it correctly)
after testing quite some different values.
The buffer setting might have different impact on different DACs/interfaces.
And it needs to be different for different samplerates, if you run very low buffer sizes.
The EDO guy also copied the buffer feature btw.
With EDO you can also play with buffer sizes. I think he offers 4 fixed values.
In my experience, if you experience edgy sound with low buffer sizes, you might need to look for another bottleneck.
You don't get a guitar tuned by just tuning one string.
Old 16th November 2012, 01:06 PM   #809
That's very interesting!!
I appreciate you taking the time to explain all that
Thanks..
CM
Old 17th November 2012, 04:16 AM   #810
gazzagazza is offline gazzagazza  New Zealand
I found low buffer settings to produce a thin edgy sound. 20000 was much better. Now I have EDO and TT3 and use EDOs large buffer setting which I think is 100000.
Sent using Tapatalk
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 11:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 10:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 09:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 04:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 04:16 PM
Copyright ©1999-2017 diyAudio
