PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 25th October 2012, 02:33 AM   #781
gazzagazza is offline gazzagazza  New Zealand
I'm new to this, and have just read my way through the thread. I have just purchased a Squeezebox Touch which will replace my SB3.
I intend applying Soundcheck's mods, however, regarding the EDO plugin, is it a good idea to install this alongside Toolbox 3.0, or should I just stick to the Toolbox alone?
Old 25th October 2012, 09:59 AM   #782
weust is offline weust  Netherlands
I just re-setup my SBT again, running latest firmware, with TT3.0.
Also got the Enhanced Digital Out app/kernel installed.
For some reason the buffer size isn't saved correctly.
It keeps sitting at the default 20000, even though the tt -i shows it's being set to 3400, and my manual action also shows it being set to 3400.
But after a reboot a tt -s shows it at 20000 again.
Think I had this without the EDO app/kernel as well, just never followed up on it.
Any reason why this might happen?
Old 25th October 2012, 10:08 AM   #783
soundcheck is offline soundcheck  Germany
If you want to run an USB DAC go for EDO.
The most important part that EDO does is a kernel update that updates the USB driver to avoid XRUNS.
As I said EDO has incorporated some of my mods. You'll make it half the way.
Soundquality improvements are not intendend according to Triode.
Though I can tell you that without freely introducing 50% of my mods into EDO many DACs would have sound worse over EDO-USB then TT30-SPDIF.
If you get along with analog/SPDIF/Toslink go with my Toolbox.
Running both tools on one system is causing a messup. You need to tweak my Toolbox by yourself for now to get both tools working side by side.
Good luck.
Cheers
Old 25th October 2012, 10:10 AM   #784
Reading that (again) I will remove the EDO kernel again.
Also got a problem playing AAC (m4a) files atm.
Flac plays fine though, so must be a server setting.
Update: removing the EDO kernel, updating/reinstalling the firmware, and installing TT3.0 shows the 3400us buffer size now.
Back to setting up everything again.
Old 25th October 2012, 09:52 PM   #785
Thanks Soundcheck. I'm running spdif out, so I'll stick with just your toolbox. I read the thread on EDO over on Slimdevices forum and I have to say there was some rudeness directed at you that I thought was uncalled for. Thanks for the work you've done, and for sharing it with us.
Is there any value in updating the LMS to 7.8 beta?
Good luck.
Cheers
Old 25th October 2012, 10:10 PM   #786
Oh, another question Soundcheck, are you running LMS on Windows 7 still? Mine is currently on an Ubuntu machine dedicated to it.
Old 26th October 2012, 10:01 AM   #787
I'm running Ubuntu Server minimal - 12.04 - 64bit - with custom rt-kernel.
With some minor modifications it IMO performs best.
Beside that I use Ubuntu Server for HiRez Video streaming (Serviio).
There is no other DLNA server performing as good as Serviio towards
my Sony Bravia. (I tried latest JRMC 18 - DLNA - they are lightyears behind Serviio - JRMC performance is aweful.)
W8 (with Fidelizer) should be better then W7. Give it a try.
At least in my and some other friends setups it's a real good choice. Systems are getting closer and closer.
Cheers
Old 26th October 2012, 02:42 PM   #788
Fukinagashi is offline Fukinagashi  Italy
Default Little confused
Hi folks,
I'm an unhappy owner of a Logitech Squeezebox touch.
Why unhappy? 'cause I'm distressed by the many mods that should make the Touch better than the basic.
Should I install the EDO mod for reading my 192/24 files?
Should I install the TT3.0?
Both?
I find many suggestions, changes to configuration and whatever else but...
...is there a synthesis of the best mods I can implement to simplify the life of the humans?
My systems:
Logitech SB (using the internal DAC)
Battery powered tube pre-amp (DIY)
PSE of two 845 per channel driven by one 2A3 (mono, DIY)
Dynaudio Contour 3.1 SE
Old 26th October 2012, 03:48 PM   #789
gk7 is offline gk7
Buy a decent DAC (donīt use the internal one) and forget about the rest.
This is the only real way to improve the sound, IMHO.
Old 27th October 2012, 12:01 AM   #790
Soundcheck, any value in running LMS 7.8 beta?
Sent using Tapatalk
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 10:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 09:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 08:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 03:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 03:16 PM
