PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 24th February 2012, 10:31 AM   #671
kelli is offline kelli
Originally Posted by phofman View Post
My suggestion would be first to try to get logged in to your SB via SSH. Once you get there, I believe some troubleshooting can be done.
That was exactly the problem: how to get the ssh access again. I have solved it!!!
I had to do a factory reboot with both SB's than I could use the remote control for both simultaneously.
Anyway - I have to give back the second SB so for the future it would be good to have an new screen or to know an other method how to active ssh again after a factory reset.
The screen connector is really physically broken - not possible to repair it. If someone has a screen and don't need it anymore - welcome!
After all: soundstage and dynamics are even more great with the HW mods (added some Blackgates to the internal clock and the SPDIF output buffer...)
Thanks for help! Stefan
Old 24th February 2012, 02:16 PM   #672
larry crimmins is offline larry crimmins  United States
The menu path to enable remote connection again is Settings -> Advanced -> Remote Login -> Enable SSH
IIRC there was conjecture early on that a script on a memory card could be written to reset this parameter and inserted in the Touch memory card slot to accomplish this and get around this convention. I think that it was John Swenson who proposed this but I don't remember if this was ever tested.
Sorry, but if you can't re-enable remote login you are fairly screwed.
Larry
Old 29th February 2012, 11:11 AM   #673
dmsims is offline dmsims  United Kingdom
Opinions on this as a Power supply
Tectrol Power Supply DC Linear Single Output 5V 3A GHOF 1-5 | eBay
Old 29th February 2012, 11:28 AM   #674
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Suitable.
If you can see the speaker cone move...it's not hifi.
Old 29th February 2012, 12:32 PM   #675
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
Originally Posted by dmsims View Post
Yuk!
well.... you asked
Old 8th March 2012, 02:11 AM   #676
errcl65 is offline errcl65  Canada
Will an upgraded 5V supply improve the sonic qualities of the digital byte stream?
I am not using the analogue output of the Touch. The Touch is strictly feeding
my DAC via RCA (75 Ohm).
Old 12th March 2012, 04:46 PM   #677
soundcheck is offline soundcheck  Germany
Hi folks.
Everything OK?
A little update:
I've been working quite some hours on server optimizations.
First W7 (server) then W8 and now back to Linux (Ubuntu Oneiric server) . Conclusion1: Linux as a server - with the right configuration though -- beats them all. ( I'm not talking about low muscles NAS devices based on Linux!!!)
Conclusion2: Server do have a severe impact on the clients. I know it sounds weired. But you can trust me. I'm not talking nonsense. Asynchronous transfers won't isolate from timing variations. ( the same is valid for async USB DACs).
Those of you who run W7-Fidelizer-TCPOptimizer should try W8++.
That'll be a step ahead. I won't outline my Linux setup for now.
Next hint:
Fileformats:
I believed that decoding flacs on the server would cure all my
problems related to realtime processing (flac decoding) on the client/PC.
I was wrong.
Now the news: Offlline decoded flacs or .wavs, even if stored on a remote server do sound clearly better. ( you know what I'm talkin about if talking
about "clearly"!?!? )
You should give it a try.
The hint of the month:
For those of you who run flacs and own a dbpoweramp license.
You might want to re-encode/re-rip some testfiles to "uncompressed lossless" flac. It's an option you'll find within dbpa
What you get is a flac with all header information and tags and PCM/WAV data inside. Great stuff.
Put those ul-flacs on the server and listen.
Enjoy.
Cheers
Old 14th March 2012, 11:49 PM   #678
findingmyway4ever is offline findingmyway4ever  United States
There is a lot of mixed discussion about this. Some say it helps, but only in a subtle way, some do not hear it due to the much nicer switching PS supplied with the Touch. John Swensen designed a PS for the device and he knows these things extremely well, so I'd follow that design if I were to use any such device.
Old 15th March 2012, 12:07 AM   #679
tonyptony is offline tonyptony  United States
Soundcheck, have you done any experiments to see if a direct WAV rip sounds better than either uncompressed FLAC, or a FLAC which had been converted back to WAV by dBpoweramp?
Old 15th March 2012, 01:25 PM   #680
Try ripping CDs in safe mode if you want the best sound quailty
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 10:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 09:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 08:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 03:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 03:16 PM
