PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 21st November 2011, 08:35 AM   #621
soundcheck is offline soundcheck  Germany
Originally Posted by AlanElsdon View Post
I am having a problem loading the Toolbox on a Mac Mini - not with the toolbox but with the changing Touch IP address. In the blog it is recommended to fix the IP address on the router - how does one do this?
I have a TP Link TL-WR642G which I use (via ethernet cable) as a hub after my Cisco modem. I can see this on the network but I have no idea as to how I can fix IP addresses.
Trying to find anything on the subject has proved very frustrating!
First you need to find out if your router supports IP reservation. Google will tell you that or just lookup the manual.
Then you need to log on to your router.
If you have looked up your LMS server or Touch IP you will know the first three numbers of the IP address and then you enter just a 1 at the end -- xxx.xxx.x.1
Usually it is 192.168.0.1 or 192.168.1.1.
Then you need to know the default user and password. See manual.
Under Setup Network Settings you usually find an arae where you can just
push a "reserve" button. I do have it on my D-Link and Cisco and Belkin.
Cheers
Old 21st November 2011, 08:49 AM   #622
AlanElsdon is offline AlanElsdon  England
Thanks - that was quick!
It seems I can reserve addresses - I will try it asap.
Old 21st November 2011, 10:20 AM   #623
korben69 is offline korben69  France
Hi Alan
Have a try here : http://www.tp-link.com/english/soft/200865140530.pdf
You'll find a hint about adding MAC/IP addresses page 44 of this manual
Old 21st November 2011, 11:06 AM   #624
Originally Posted by korben69 View Post
Hi Alan
Korben
Thanks for the link, I have tried to reserve an address but at the moment it is being rejected - however a friend who knows about networks will be sorting it for me. I will setup the Touch using todays address and fix it at a later point.
Alan
Old 24th November 2011, 05:31 PM   #625
magiccarpetride is offline magiccarpetride
Originally Posted by findingmyway4ever View Post
-I have read everywhere that a better PS does absolutely nothing, this coming from both users that have benchmark-lab grade massive PS's to test devices in order to see if they improve performance along with others that have tried offerings from Boulder/Modright/etc. In this specific thread, it was concluded, even by people doing loads of clock+other HW tweaks, that the PS does nothing for sound improvement. Noteworthy of this thread is one person that kept insisting, in spite what others were saying, that their PS made a "dramatic" difference to the sound. But again, this is only one person, and the others in this thread were very serious into modifying or having extremely hi-end equipment/systems/etc.
I can only think of one thing: Though all PS's should be the same, maybe the Touch only likes a specific built one??? And what specific built one that is, maybe the people in the UK that you got yours from know the magic trick to the touch's sensitive nature?)
Myself and others have experienced very palpable change in the sound quality when replacing the PSU that ships with the Touch with a higher quality one.
In my case, I've originally purchased my linear PSU for my DAC. It made a dramatic change in the sound quality, but unfortunately for the worse. It flattened the bass and completely removed the slam that my DAC is famous for.
I've quickly reverted back to the PSU that shipped with my DAC (that PSU is NOT a wall wart), and things were brought back to normal (whew!)
Then, just for a lark, I've repurposed my linear PSU and plugged in into my Touch. Holy Moses! -- completely changed the sound, and for the better! The best way to describe the change is to say that it cleaned up the sound. The difference between the wall wart that comes with Touch and the linear PSU is
to say that it's like the difference between a dirty, dusty car and the car that just came out of a car wash Clean, shiny, sparkly.
I strongly recommend people try replacing their wall wart with a decent linear PSU.
Old 1st December 2011, 02:06 AM   #626
tallnick is offline tallnick
just got 3.0 to work on mac osx if anyone needs help.
Old 1st December 2011, 02:38 AM   #627
RKH is offline RKH  United States
I am new to this thread... but for osx, are there tweaks to the process listed on the blog?
Ryan
Lighten up while you still can ...
Old 1st December 2011, 05:18 AM   #628
the only thing I would add to the blog is that you need to place the toolbox .tar file in your /users/ folder.
for example, I had to open up my harddrive, click on my username under "places" and put the file there alongside desktop, documents, downloads, etc.
otherwise when I tried to unpack the archive using the "tar xvf . . ." command it kept coming up saying no such file exists.
now I have it working and I have to admit I'm shocked at the sound quality improvement. I was skeptical if I'd be able to tell a difference, but I'll be damned if my system doesn't sound even better. Amazing stuff and hats off to Klaus for the amazing work.
if you have any further questions let me know. I copied exactly what I typed into terminal so I can reference it any time and help others (or myself) out.
Old 1st December 2011, 06:34 AM   #629
You unpack the archive on the Touch!! Just to avoid any misunderstandings.
If you exactly do what I wrote the file should be on the Touch - under "/" ,
if you do it the Linux/OSX way.
It's up to you to download the archive from teh web and to put it any place on your machine.
You just need to figure out on the OSX sidewhere you put that file and then you need to cd into that directory to be able to copy it.
You of course can also run scp with the full path + filename .
Let me know if there is a standard per user download directory under OSX. Perhaps you can tell me the full path of it (cd into it and type "pwd").
Cheers
Old 1st December 2011, 08:35 AM   #630
I managed to get it working on my Mac Mini - downloads automatically go to a directory called Downloads (i.e yourusername/Downloads - in my case alanelsdon/Downloads). When you initially login to Terminal it goes into yourusername e.g. alanelsdon so all you have to do is 'cd Downloads', if you now 'ls' then you should see touchtoolbox-3.0-LAN.tar in the list.
/Users/alanelsdon/Downloads is the path.
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 10:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 09:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 08:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 03:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 03:16 PM
