PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 24th October 2011, 01:03 PM   #521
soundcheck is offline soundcheck  Germany
Hi folks.
TT 3.0 - the tool - is ready for release now.
I hopefully got all the little issues fixed.
I now need to prepare the documentation stuff around it.
It'll take me a day or two.
The feature list reads as follows:
* heavily improved installation process
* full integration of all mods into just one tool
* help function
sound related:
* task priority tuning
* networking parameter tuning
* networking configuration related adjustments
* kernel parameter adjustments
* screen on/off during operations (no more reboot required)
* infrared on/off
* exclusive audio routing
* the daemon killer (you'll love that one)
* volume lock at 100 % (for testing purposes)
* tested on systems up to SBS 7.7.0
Stay tuned.
I'll be back.
Old 24th October 2011, 08:17 PM   #522
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi soundcheck,
Just got a squeezebox today. And ofcourse I would like to try your toolbox.
Would you suggest I get used to the sound of the touch before I do any updates?
In any case I tried to use WinSCP. And as described I used:
Start WinScp.
1. Enter the Touch IP address in the "Hostname" field.
2. As user you enter "root", as password you enter "1234"
3. As protocol you select "SCP"
4. Press "Login" and confirm the pop-up (ssh key generation) with yes.
I found the ip address for the touch. But are the username and password really as given? And what port number should I use.
I'm asking because the connection gets refused.
Network error: Software caused connection abort.
If you can see the speaker cone move...it's not hifi.
Old 24th October 2011, 11:37 PM   #523
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
Bas, you have to enable SSH in the Touch advanced menu. On the acutal squeezebox touch. otherwise connection will be refused.
Old 25th October 2011, 06:59 AM   #524
Thanks erin,
will try.
Old 25th October 2011, 07:16 AM   #525
Originally Posted by Bas Horneman View Post
Hi soundcheck,
You should start with the stock Touch to get used to it. But don't overdo things.
I can tell you operating the box at stock level I consider quite disappointing and boring. You'll get what you pay for.
It requires a certain ambition level to make that device sing. The good thing about is that
the device got the potential.
Logitech should have launched a no frill black box digital only streaming device as lean as it possibly can get. I wouldn't expect such a device to cost more then 100$. They
could sell these like mushrooms.
Cheers
Old 25th October 2011, 08:27 AM   #526
I have had the Squeezebox 3 for years. Always through ethernet. I've been using a RAKK DAC mk2. Had a linear psu (which I'm using for the touch). And I found the touch out of the box better as a transport.
Cliché coming up: It sounds more analog. Less shouty. Quite suprised already especially since I only use it as a transport.
Old 29th October 2011, 08:24 AM   #527
Folks.
Status Update
My "norwegian beta-test branch" , reported slight instabilities of TT3.0 last night.
I hoped that I got the reporeted issue under control.
I need to look into it. Sorry.
As soon as I get it fixed TT3.0 will be released.
Cheers
Old 29th October 2011, 10:03 AM   #528
Shutdown98 is offline Shutdown98  Netherlands
Better safe than sorry
I
Old 29th October 2011, 11:20 AM   #529
Better safe than sorry!
I will wait as patient as possible ;-)
Old 31st October 2011, 06:57 PM   #530
Vogelius is offline Vogelius  United States
The link to TT 2.0 is no longer available, viz.
Page not found
Sorry, the page you were looking for in the blog soundcheck's - audio@vise does not exist.
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 10:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 09:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 08:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 03:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 03:16 PM
