Squeezebox Touch -- Modifications - Page 52 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 18th October 2011, 08:22 PM   #511
Originally Posted by erin View Post
Thanks very much. I'll try it out.
The problem is fixed for me with the RC6 build and was confirmed by Andy to be fixed. This build: 7.7.0 - r33614
By the way.........the Soundcheck mod's work just fine on this build. Thanks Klaus and looking forward to the new release!
Old 19th October 2011, 03:12 PM   #512
god im definitely late on this thread.
i have the SBT and have a had drive plugged into the usb, what i would like to know is it better to have a NAS plugged in or is a basic HDD ok?
Also following soundchecks excellent blog, how do i modify the squeezebox server setup with regards to flac, do i enter the SBT IP address and go in trhough that. as server is currently installed on the HDD??
cheers.
Old 20th October 2011, 03:06 PM   #513
longmanjon:
If I understood you correctly, you are running your Touch w/ a HDD connected via the USB input. The version of SBS (tiny) you are using is actually onboard the Touch itself and while it works, is generally reckoned not to provide the best quality of playback.
A separate PC, (it needn't be the the latest and greatest) w/ SBS installed and your music drive attached, will be a big improvement. Connected via ethernet and also connect the Touch via ethernet (to your home network) and then the server setup instructions will start to make more sense.
Larry
Old 20th October 2011, 07:43 PM   #514
hey larry, yes you have it right. i thought that the server got installed on the HDD but i must be wrong. i didnt really want to have a pc connected for this to happen, i quite like the simple approach that i have but it seems it may not be right.
Old 22nd October 2011, 06:41 AM   #515
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Hello.
I know, that this may allready been discussed, but is there a possibillity to EQ the output of the Squeezebox Touch ?
I have been reading about the Brutefir, but it doesent seem to work on the Touch.
I am running the newest Squeezebox server.
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 22nd October 2011, 08:22 AM   #516
soundcheck's Avatar
Originally Posted by lykkedk View Post
Hello.
Jesper.
You can run brutefir on the SBS server, a Linux server. There's a plugin available.
One little disadvantage is that you need to send flacs down to the client.
Old 22nd October 2011, 08:26 AM   #517
soundcheck's Avatar
Folks.
I'm a little delayed. I found some minor problems which I need to fix before I can release TT30. TT30 should be running at least as stable as TT20.
I can't afford to answer tons of mails about this or that minor issue.
Today I'm out - there's a rather big audio show close by. I can't miss that one.
I hope I'll manage tommorrow.
Cheers
Old 22nd October 2011, 08:41 AM   #518
lykkedk's Avatar
Thanx Klaus...
I am running my server on a ubuntu super fast text -only server on some very old fan -less micro -itx card (800Mhz)
Till now, i newer did the encoding on the server, so if the Brutefir can work, i guess i have to try it out.
Jesper.
Old 22nd October 2011, 11:50 PM   #519
Send a message via AIM to lake_eleven Send a message via MSN to lake_eleven Send a message via Yahoo to lake_eleven
I bought the high-quality Ethernet cable that soundcheck recommends (about 7 Euros for 2 meters) and removed a bit of the shielding close to my Squeezebox as he recommends. No other solution (cheaper cable, fully shielded cable, another Ethernet switchbox in between) worked well. The differences are there; apologies to the laws of physics and engineering.
Any suggestions on how to do this?
Old 23rd October 2011, 12:15 PM   #520
@lake_eleven
Just apply Soundcheck's instructions in section 2.2 of soundcheck's - audio@vise: soundcheck's Squeezebox Touch Toolbox 2.0
"I'm currently running Draka UC900 S/FTP cable with Hirose Plugs TM31!!!
(TM31P-TM-88P,) they sell at a couple of $/€ over here in Europe. I paid 6-7€
for 1m.
Note: I did remove the shield of my cable ( it's an S/FTP) 2 inches away from the
connector to avoid a ground loop into the Touch. That puts at least one
leg of that patchcable on ground.
Advise: Watch out -- many of those cables come with e.g. Hirose TM21 instead
of TM31 plug! This can make the difference! "
...and it definitely works! I have gained great improvement in the mediums. For me it is one must have and most audible improvement.
Buy the cable and carefully remove the jacket and the metal shielding on 2 cm close to the connector (side of the Touch) without damaging the 8 wires inside. For a dummy like me it was almost like a peace of cake so you should be able to do the same.
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 10:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 09:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 08:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 03:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 03:16 PM
Copyright 1999-2017 diyAudio
