PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 9th January 2011, 09:50 AM   #201
atchi123 is offline atchi123  United Kingdom
just a quick question, whenever I apply a mod and the Touch reboots, the IP address of the Touch changes so I cannot reconnect without re-defining the Ip address in WinSCP login. Any way to stop this (probably a very noobie type question I know)
Old 9th January 2011, 10:14 AM   #202
Shutdown98 is offline Shutdown98  Netherlands
If you do a complete factory default on the touch, unplug your router (as it probably will be the DHCP server). In the touch setup you choose for cable network. The touch will be searching and eventually you can enter static ip settings. Then you can connect the router again.
Old 9th January 2011, 10:45 AM   #203
soundcheck is offline soundcheck  Germany
Hi.
Yep. That's known fact.
You should "reserve" a fixed IP address for the Touch on your router.
Modern style routers let you do this easily in the network setup.
Otherwise you got to look that IP adress up everytime you reboot the Touch.
I wouldn't recomend working with static IPs, which is much less flexible
then working with reserved IPs in a DHCP environment.
Cheers
Old 9th January 2011, 10:48 AM   #204
Hi folks.
I changed from beta to normal status. Things seem to run pretty stable.
I did some little adjustments on the blog text. The toolbox itself stayed as
it was.
Cheers
Old 9th January 2011, 11:42 AM   #205
mrdon is offline mrdon  United States
mrdon's Avatar
To remedy this, best practices indicate that the IP address be reserved based on a device's MAC address. In the case of the Touch, this can be found on the sticker on the bottom of the device. When this is done, every time your device reboots and/or your router, your Touch will always be at the same IP address.
This exercise is performed differently on every router, so please consult your owner's manual for further guidance. Alternatively, Logitech has setup instructions for a number of routers on their Support site.
For Netgear routers go here
For D-LINK routers go here
For 2WIRE routers go here
Old 9th January 2011, 11:50 AM   #206
mrdon's Avatar
Originally Posted by soundcheck View Post
Hi folks.
it was.
Cheers
Klaus,
One suggested correction to the written instructions.
In the 1.2.7. Linux/OSX (commandline) section, one line (in bold below) needs to include one correction.
4. Unpack the archive:
ssh root@Your-Touch-IP-Address:
Password: 1234
cd /
tar xf touchtoolbox2.0.tar
(not <tar xvf touchtoolbox2.0.tar> as you currently have it listed)
Old 9th January 2011, 12:02 PM   #207
I don't think there'll be a difference.
Old 9th January 2011, 12:18 PM   #208
mrdon's Avatar
I believe omc and myself have run into <tar xvf touchtoolbox2.0.tar> not working for us. When I tried omc's suggestion of removing the verbose output command <v> and making the command line <tar xf touchtoolbox2.0.tar>, it worked for me.
Old 9th January 2011, 01:08 PM   #209
Dremel is offline Dremel
Hi Klaus,
The new version works perfectly and the sound is wonderful. You did a great job. Thanks.
Old 9th January 2011, 02:56 PM   #210
dnewcomer is offline dnewcomer  United States
I seem to be having problems trying to set the buffer size.
here is the output from the log:
<result success="true" />
</call>
<call>
<command value="ttbuffer 4000" />
<destination value="/" />
<output value="4000
__________________________________________________ ______________
soundcheck's SB Touch Toolbox 2.0: The buffer mod!
Buffer set to 4000 us. Rebooting system.
<erroroutput value="sed: unmatched '/'" />
<result success="false">
<message>Server unexpectedly closed network connection.</message>
</result>
</call>
</session>
any ideas? everything else so far has been working ,
ttout -d, and tt --wlan were all successful
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 11:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 10:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 09:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 04:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 04:16 PM
Copyright ©1999-2017 diyAudio
