PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 8th January 2011, 02:03 AM   #171
omc is offline omc  Canada
remove the w from tar xwf touchtoolbox2.0.tar it is an unrecognized command. it worked for me.
Old 8th January 2011, 02:06 AM   #172
My God
The work you put into this is quite something Klaus. I am very impressed.
Old 8th January 2011, 02:07 AM   #173
on and off for the screen is so usable!
Old 8th January 2011, 02:23 AM   #174
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
tar -xv -f touchtoolbox2.0.tar ???
Greg Erskine
Old 8th January 2011, 02:29 AM   #175
1.2.4
the command should be
tar xf touchtoolbox2.0.tar
Old 8th January 2011, 02:47 AM   #176
1.2.4
Have you tried tar -?
Greg Erskine
Old 8th January 2011, 02:51 AM   #177
well tar, it doesn't taste that good...
I am not sure what you are asking
Old 8th January 2011, 03:02 AM   #178
If you type:
tar -?
it will give you help on how to use the command.
EDIT: On closer inspection it should be "tar -h" not "tar -?"
# tar -h
BusyBox v1.16.2 (2010-12-28 05:38:36 MST) multi-call binary.
Usage: tar -[cxtzvO] [-f TARFILE] [-C DIR] [FILE]...
Create, extract, or list files from a tar file
Options:
c Create
x Extract
t List
Archive format selection:
z Filter the archive through gzip
File selection:
f Name of TARFILE or "-" for stdin
O Extract to stdout
C Change to DIR before operation
v Verbose
regards
Greg Erskine
Old 8th January 2011, 04:30 AM   #179
larry crimmins is offline larry crimmins  United States
now the link to the rest of the commands after installing the tar archive are not available. I'm worse off than when I started.
Old 8th January 2011, 08:51 AM   #180
soundcheck is offline soundcheck  Germany
Hi guys.
Thx all of you BETA testers for now.
As I said - official launch will be Sunday. Don't worry we'll manage.
1.
There've been a blogger problem ( one out of many others I stepped into) with the reference link.
Try this direct link instead :
Touch Toolbox 2.0 blog
Perhaps I'll change from blogger to wordpress soon.
2. The download of the file seems to work for me.
I received comments that the upgrade was working fine for others.
3. If you're not sure what and how to write a command, just try a simple
Copy/Paste.
4. Make sure that you follow the instructions. Especially those telling
you to run a factory reset before you start. If you got my old stuff
installed the upgrade will fail if you don't do that.
And 2. in case the Touch hangs up during boot (this might happen during
the upgrade process only!!), just unplug the power cable to do a hard
reset.
5. I changed my signature pointing to the right link btw.
Cheers
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 11:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 10:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 09:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 04:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 04:16 PM
