PC Based Computer music servers, crossovers, and equalization
Squeezebox Touch -- Modifications
Old 6th December 2010, 11:12 PM   #91
larry crimmins is offline larry crimmins  United States
Buffer mod?
Unhook display?
Old 7th December 2010, 07:05 AM   #92
omc is offline omc  Canada
If you go through these posts you will see both are discussed at length. Some people are opening the units up and unhooking the screensn
Old 7th December 2010, 09:15 PM   #93
It seems that there were a number of mods added to the site at a later date, i.e. the buffer mod, so I am not familiar w/ that one.
The discussions on this site do not explain how these are accomplished either.
Any disabling of the screen would also lock you out of the ability to turn on remote login to the secure shell interface. This strikes me as a step backwards.
Old 7th December 2010, 10:09 PM   #94
atchi123 is offline atchi123  United Kingdom
Omc, could you post the old mods? I lost them too...
No sign of the new scripts any sign of soundcheck chap?
Old 8th December 2010, 12:00 AM   #95
I just made a google doc of it. Lets see if it works
https://docs.google.com/document/d/1...254/edit?hl=en
Just to clarify; this google doc is the soundcheck page from before the buffer mod was added. If anyone has a newer version or a buffer mod file, please let me know and I will add it.
Old 8th December 2010, 12:03 AM   #96
All of the links on the doc seem to work too.
Old 8th December 2010, 02:48 AM   #97
Thanks for posting this.
I'm still hoping for a SW solution to shutting off power (and noise) to the screen.
The buffer mod, apparently, would also be a nice addition.
Whenever Klaus posts the updates.
Old 9th December 2010, 02:00 PM   #98
pefect, thanks for posting the script...just running now.
still no sign of updated scripts on the audio@vise blog...
Old 10th December 2010, 10:07 PM   #99
I was wondering if many people were running their SBT with the flac disabled, so that pcm is fed trough the lan. I am finding that it works quite well for me for redbook flac, but not so well for 24/96. I notice that 24/96 is converted to 1411kbps PCM, which is the same as redbook. The sound is definitely degraded. I am wondering what to do. I am buying high res stuff from HDTracks. Can I convert this into high res wave files so that it is dealt with differently. If anyone is doing this, could they please let me know works well for them.
Old 11th December 2010, 02:36 AM   #100
mb is offline mb
I run all my flac audio to the SBT in pcm, but there is a twist in that I use brutefirdrc room correction in between. Nevertheless it's puzzling that your pcm would be downsampled.
The converter instruction for flac to pcm conversion is:
flc pcm * *
# FT:{START=--skip=%t}U:{END=--until=%v}
[flac] -dcs --force-raw-format --endian=little --sign=signed $START$ $END$ -- $FILE$
Flac is decoding to raw, and there's no downsampling. How did you verify that the pcm is converted to 44.1kHz?
I first tested pcm playback without brutefir, and it seemed to me that the sound was clearer and more flowing for 44.1 and HDTracks hires material.
Squeezebox Touch -- ModificationsHide this!Advertise here!
question to Squeezebox Touch users Martin Prothero PC Based 50 13th August 2010 11:27 PM
Which PS for Squeezebox Touch upgrade? Twisted Pear Placid, or AMB σ11? orpheus PC Based 8 4th June 2010 10:52 AM
Squeezebox Receiver Modifications jkeny Digital Source 3 12th March 2010 09:22 AM
Finish of the speaker, the final touch.. thanx Multi-Way 3 20th November 2007 04:12 AM
Squeezebox 3 I_Forgot Digital Source 0 3rd January 2006 04:16 PM
