| PC Based Computer music servers, crossovers, and equalization |
#31 | |
now it is playing very nice @s24le/48000 tried it in windows 7 as well...same thing everything higher then 48000 distortion... I think it is the teradak.... I have a brandnew computer since last week (HP HPE320 with optical out and internal (lousy) hd audio...) but I can manage to let it play in ubuntu and windows 7 @24/96000... I think I will look for a real soundcard with optical out @192000... sugestions? kind regards, Tony |
#32 | |
maybe there was a misunderstanding due to my bad English knowledge but i don't ear distortion at 96000/S24_3LE. I only have a little doubt about the bit perfectness of the device 0 of this card and till now i had no time to test this, when i will do it i will let you know. Ciao Andrea |
#33 |
i built a little coax -> optical spdif interface to test my card and i can say that it is bit perfect for 48/16 and 96/16. I have tested it with "aplay" on the card under test and "arecord" on another card with optical spdif in, then i compared the original wav file with the recorded one with "wavdiff" (http://axel-sommerfeldt.de/wavdiff001123.zip). Obviously this test gives bit perfect results only with the PCM volume control on "alsamixer" for the card under test at 100%. I couldn't test the card with 48/24 and 96/24 wav because wavdiff works only with 16 bit wav files. I would like to know if someone knows another program to compare wav files (similar to wavdiff - it handles files with different length and different silence offset on the head) that can cope with 24 wav files. Ciao Andrea |
#34 |
Andrea,
I played with testing bit-perfectness quite a lot and could not find any automated tool. wavdiff was OK (for 16 bits), but it could not align wavs with minor distortions at the beginning (not all recorded tracks from spdif-in started with zero samples). I ended up truncating and aligning the two tracks in audacity (with a bit of practice it does not take more than two minutes). Subsequent comparison - subtracting the aligned wavs is straightforward in SoX. If you are fine with wavdiff, its C code is nice and clean, it should not be difficult to modify. Perhaps |
#35 |
Hi phofman,
Thanks for your replay. I will go on with bit-perfectness testing following your hints in two way: 1) Short term: Audacity editing + SoX. 2) Long term: i will try to modify wavdiff for 24 bit. Ciao Andrea |
#36 |
OK bit perfect also @ 96/24
tested with aplay, arecord, audacity editing and sox subtract and stat: sox -V -m outgoing.wav -v -1 incoming.wav -n stat Ciao Andrea |
#37 |
Let's bump this thread...
Did someone come up with any substantial mods for this device ? |
#38 |
| FS: Antek Torroid 40V x2, 18V x2, 800VA | dweekie | Swap Meet | 0 | 7th July 2008 12:24 PM |
| x2 preamp | bpucekov | Pass Labs | 1 | 11th January 2006 09:05 PM |
| Pass pre X2 vs X2.5 | Duck-Twacy | Pass Labs | 2 | 23rd January 2005 08:08 AM |
| And another review (X2.5) | Duck-Twacy | Pass Labs | 0 | 23rd November 2003 05:42 PM |
| Pass X2 and BOZOZ | bigswede | Pass Labs | 2 | 7th January 2002 10:20 PM |
| Page generated in 0.11577 seconds (81.69% PHP - 18.31% MySQL) with 11 queries |
