Audiolense and J River with a Lynx 2B HTPC Audiolense and J River with a Lynx 2B HTPC - diyAudio
PC Based Computer music servers, crossovers, and equalization
Old 16th March 2010, 12:42 AM   #1
MerlinGS is offline MerlinGS  Canada
Default Audiolense and J River with a Lynx 2B HTPC
Hi Everyone,
First, I apologize for the cross-post, but I think my original thread was posted in the wrong sub-forum.
I have been fooling around with DIY speakers for a while, I used to be a member of the bass list and now mainly participate at AVS. There are a couple of projects I have been procrastinating on which I would like to get started with, but I'm having some difficulty with the PC side. I'll start with my first and simpler project.
Anyone running a Linkwitz Orion with a digital x-over?
Anyone know the transfer function for the Linkwitz x-over so that I can use the same with a digital x-over?
Any thoughts on using Audiolense and J River with a Lynx 2B card to run a digital x-over for Linkwitz Orion speakers?
How seamless is the Audiolense when used in conjunction with J River?
How good is the DRM in the Audiolense?
I J River able to handle running a 6 channel digital x-over with few problems?
Any insight would be appreciated.
Old 16th March 2010, 01:13 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Hi and welcome to the forum.
While I don't have answers for you, I would like to know how it turns out. I run JRiver and an active crossover, but send 2 channels out of my sound card.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 18th April 2010, 06:44 PM   #3
OMF is offline OMF  Norway
Originally Posted by MerlinGS View Post
Hi Everyone,
I think that would be a great idea! You will achieve the benefit of the radiation pattern, and still have the benefit from active X-over
This is a very good match! - works very well i assum - I am using the Lynx AES15 in same set up
Perfect - no glitches, pops - only a short delay from hitting play until music starts - depending on the filter lenght!
DRM...? I am not sure what you mean...but there are quite a few of us here in Norway using Audiolense - and I believe we are pretty happy
Yes - Ia m running 3 way active crossover in stereo- No problem!
Running the filters created by Audiolense in JRiver is very easy. JRiver is also very stable, have a few Audiphile goodies, and a very good remote control function!
Best regards
OMF
Old 26th April 2010, 08:37 PM   #4
Hennie is offline Hennie  South Africa
Being a dipole the Linkwitz Orion needs lots and lots of equalization at the LF end. If I am not mistaken, Linkwitz himself has cautioned against the use of a digitally implemented crossover due to a possible loss of resolution.
Perhaps just check the LF boost required. Although he does not provide the exact transfer functions of the Orion, it is possible to do rough calcs using the theoretical models he provides.
Old 26th April 2010, 11:44 PM   #5
kevinahcc20 is offline kevinahcc20  United States
kevinahcc20's Avatar
Default What's Wrong with SL's ASP
I recently finished building a pair of Orion+ including SL's ASP. The performance of this speaker system is simply amazing. What improvements do you think are available via DSP...Linkwitz seems to be a seminal thinker/technician & my sense is that if he could have obtained better perfomance using DSP, he would have gone that route.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 28th April 2010, 02:44 AM   #6
boconnor is offline boconnor  Australia
My guess is that just duplicating the transfer function of the analogue crossover would probably not have much utility. The real advantage of DSP/DRM is that you can account for the bass frequency room modes and smooth the room response below 100Hz, and get all your crossover action done from the one unit (PC etc).
Old 28th April 2010, 12:41 PM   #7
Default Agreed...but
boconnor,
Agreed that would be a useful adjunct from a DSP unit. I have been pleasantly surprised by how the bipolar OB woofers on Orion are much less prone to excite room modes than a typical box...bass response is very smooth & quite deep even without the Thor subwoofers. Also the Orion ASP includes one unused but available active notch filter that can be used to tame a dominant room mode by selecting appropriate feedback components.
Thanks!
Old 28th April 2010, 01:41 PM   #8
From what I understand the Orions are fabulous speakers, and SL seems genuinely knowledgeable and talented. However, even a dipole can't prevent room modes being excited (even if they pump less energy into the modes compared with sealed boxes) - so there are still benefits in digitally eq'ing the sub 100Hz region.
True, but I suspect that in taming closely spaced modes, one notch filter is not going to compete with say a 4000 tap FIR filter, which is typically available from the DSP software programs.
Audiolense and J River with a Lynx 2B HTPCHide this!Advertise here!
Audiolense, J River, Lynx 2B dig x-over, Linkwitz Orion MerlinGS Multi-Way 3 23rd March 2010 12:26 AM
Radian 5208C or 508/2B 8" coax, anyone? GordonW Multi-Way 8 10th January 2010 05:57 PM
Polk SDA 2B FS make offer 00600 Swap Meet 0 15th September 2007 01:40 AM
Alembic F-2B mbonus Instruments and Amps 3 3rd March 2006 04:55 PM
Modifying a Bryston 2B amplifier .. JinMTVT Solid State 3 26th July 2004 08:04 AM
Copyright ©1999-2017 diyAudio
