Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 8th March 2010, 11:04 PM   #1
percy is offline percy  United States
Default Weird freq response due to Win 7 ?
Audigy 2 NX USB soundcard. Just for kicks hooked it up to my new laptop that has Windows 7 and did some measurements. I am having a very strange and weird issue with it.
The issue is that the frequency response of the card when recording only (playback is fine) has a series of huge (+12 to 18db!) peaks. I also see a sort of pattern to these giant peaks. They seem to be odd multiples of 1100hz.
What could this be ? Is there anyting about Win 7 or the soundcard drivers ?
I have used/measured this soundcard on a XP desktop and it has worked just fine.
Any ideas ? Has anyone experienced such a thing with any soundcards on Win 7 ?
Old 11th March 2010, 12:26 AM   #2
first download latest drivers, than try going trough WASAPI if possible
Old 11th March 2010, 12:58 AM   #3
how does one 'go through WSAPI' ?
Old 11th March 2010, 01:14 AM   #4
5th element's Avatar
This would be program dependant. For example Foobar 2k has a component that allows you to use WASAPI as the output. This isn't something typically supported by a lot of programs, they usually use ASIO if anything. WASAPI is another way to bypass the windows mixer and any software re-sampling windows might be doing.
I've been having no problems with windows 7 when it comes to my PCI sound card. With the PCM2706 USB chip I had no problems either.
One thing that it could be is an inconsistency somewhere with the sampling frequency. You should be able to alter this in the 'Sound' tab in the control panel. Make sure the program your using is set to use same sampling frequency that the card is set to.
I know that if I've got 96khz selected and I try to do a FR sweep at 48khz or similar I get deviations in the frequency response.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 17th March 2010, 03:25 AM   #5
I figured this out. It was due to the Line In volume in the "playback" mixer settings. When I muted it, everything worked just fine. Must be creating some sort of an internal loopback and causing strange feedback. All is well now!
Old 22nd March 2010, 03:38 AM   #6
I installed the WASAPI plugin for foobar2000 and I certainly hear a large difference. I'm not really sure what windows was doing, but now everything sounds much better.
Output data format is set to 24bit.
TL freq response bigwill Subwoofers 6 13th July 2005 07:02 PM
Overall freq. response *that* bad? Onvinyl Analogue Source 7 13th April 2005 06:27 PM
External reclocking and error due unequal input data and clk freq. andy2 Digital Source 8 3rd April 2005 02:51 PM
how to measure freq response skyraider Solid State 23 20th January 2004 07:08 AM
Looking for Monacor freq response off-axis mgrzemow Multi-Way 0 20th October 2003 11:10 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
