PC Based Computer music servers, crossovers, and equalization
HD Media players
HD Media players
Old 2nd February 2010, 08:15 PM   #1
Martin Prothero is offline Martin Prothero  United Kingdom
Martin Prothero's Avatar
Default HD Media players
Hi
I wondered if anyone has comments about using HD Media players like this one (link below) as the source for a high end Hifi system? I would rather not use my computer.
http://www.amazon.co.uk/Western-Digi..._tdp_sv_edpp_i
I need it to be able to output USB (for my DAC) as well as accept optical in, and stream 24/96 native wav files.
Am I barking up the wrong tree or is this exactly the kind of thing to be looking at instead of a laptop or high end (high price) server?
Any other suggestions welcome
Thanks in advance
Keep a green bough in your heart, the singing bird will come.
Old 3rd February 2010, 07:34 PM   #2
No one want to answer? Is it that obvious. I just wondered if they are good at streaming wavs or if they are really meant for movies?
Old 3rd February 2010, 08:42 PM   #3
hoxuanduc is offline hoxuanduc
OK, I'll bite.
I used this player a while back, since I had a whole bunch of FLAC files on the hard drive. I didn't like it:
- File navigation is pretty akward - no tagging capabilities whatsoever
- Sound quality is really bad - compared to external USB DAC.
For movies, I couldn't get it to play VOB contents. Tried to convert the files to
whatever format was supported. The software keeps crashing.
So I returned the item - Now I have PC running Windows 7 for both movies and music. More expensive, but also more flexible and better sound and ease of use.
Conclusion: poor execution of a sound concept.
Edit: it doesn't have USB Out or accept digital in. Don't know if it can play 24/96 wave files.
___
Duc
Old 3rd February 2010, 11:07 PM   #4
sjdemark is offline sjdemark  United States
If you are looking mainly for a music play, I really like the Squeezebox or Transporter. The sound is very good, and it does have digital outs. The downside is the you do need a computer up and runner somewhere in the house, but it doesn't need to be expensive. The server software does not take many computer resources, and I use a 4 year old computer as my server and just leave it on all the time, while sitting in the storage room.
Another nice things about the Squeezebox is you can get several of them and sync them when you are having a party to get whole house audio.
Old 4th February 2010, 09:00 AM   #5
Berndy is offline Berndy  Germany
I do this for a long time, but only with toshlink and digitalcoax.
It's ok for background music, nothing else, cause jitter is very high.
Then I connect per USB, the best connection for hifi, but it doesn't work.
The reason is simple, you need an operating system that load the right driver.
But a multimediaplayer has no operating system.
Old 4th February 2010, 12:54 PM   #6
Default hummm
Thanks for the pointers guys. I will avoid this then!
I am trying to simplify things and not use a computer if poss. I have a mac but that is for work (I work from home) and I want to switch it off sometimes and have some of my own time away from it!
I am going to make a USB NOS DAC (Peter Daniel audio-sector) and I wanted to see if there is a solution to enable me to store and stream wavs to the USB DAC.
Does this really need to be big bucks?
Old 7th February 2010, 06:37 AM   #7
dangus is offline dangus  Canada
HD Media players
The WD TV does have an OS... Linux. I expect most of the other players do as well. However, the audio/video code is specific to the chipset and not part of the GPL. Maybe it would be possible to ignore the regular AV stuff and use normal drivers to support a USB audio device, and an alphanumeric LCD display instead of a TV or monitor. On the other hand, the same could probably be done with a hacked WRT54G or XBox or embedded PC.
Old 7th February 2010, 09:43 AM   #8
I can just use my 4 year old Mac laptop, take everything off and use it specifically as a music server but I was hoping to find an alternative. The idea of having a small black box that can boot up almost instantly (or be left on standby) seemed cleaner somehow but I guess I need to keep looking for alternatives.
Thanks for your help so far chaps
Old 7th February 2010, 10:20 AM   #9
sandyK is offline sandyK  Australia
Martin
I was thinking of getting one of these as reviewed at the attached link. However I decided against it after finding out that Optical OUT, downsampled to 48K.
It has been getting excellent reviews in the local PC magazines, and sells for under AU $200 in Australia.
SandyK
bit-tech.net | Review - WDTV Live HD Media Player Review
Old 7th February 2010, 10:27 AM   #10
Hey SandyK. Important info there. I will defo avoid now. I really would like it to stream 96khz.
Does anyone know about the Lacie LaCinema (Mini). Maybe I should just avoid all of these media devices altogther? LaCie - LaCinema Mini HD
HD Media playersHide this!Advertise here!
What Ever Happened To The A/V Media? mowry Everything Else 0 8th July 2009 01:15 AM
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 08:31 PM
media players fetching lyrics rick57 Digital Source 10 28th October 2006 04:31 AM
Windows media players ~ interface, data, sound Q rick57 Digital Source 3 24th October 2006 01:32 AM
Dlink wireless media players Sandor Digital Source 1 9th January 2006 12:20 AM
