PC Based Computer music servers, crossovers, and equalization
Question about distributing audio
Old 19th January 2010, 08:26 PM   #21
xerocomm is offline xerocomm  United States
xerocomm's Avatar
Originally Posted by scott wurcer View Post
OK devils advocate here, I decide that a certain opera needs to be played back at 95kHz to sound right, but that sound card is only on one of my computers. Asynchronous TCP/IP streams should work fine with any output clock frequency (within reason) via sufficient buffering. My point is the output clocks are local and not synchronized to the data stream. The server could care less what frequency the output is at. It simply serves a data stream when asked.
BTW hats off to your software contribution.
You are absolutely correct now that I understand the application!
Old 19th January 2010, 08:35 PM   #22
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
I have been researching media servers for a while anyway so I read some of the Squeezbox blogs. Apparently there can be lots of latency issues related to OS and particular hardware, even a 2msec difference sets up a 500, 1000, etc. comb filter effect. That Java app that they mention might help some too.
I tried Orb but at work I have firewall issues and I could not get my favorite radio stations. Orb's list seemed limited, some apps list 30,000 stations? At home I can leave it on a spare machine 24/7, I would really love for my TIVO content to show up.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 19th January 2010, 08:45 PM   #23
xerocomm's Avatar
Post VLC Multicast
Multicast is the key word here and I just missed the point sorry for wasting everyones time. Let's try this again!
Download free VideoLan (VLC) at VLC media player - Open Source Multimedia Framework and Player
Install VLC on every computer that you want to play the same music simultaneously.
Google "VLC Multicast" here are some link that looked helpful: http://www.gctglobal.com/Products/Se...ast_by_VLC.pdf
How to Use Vlc to Stream Audio and Video to Multiple Computers on Your Network Using Multicast: 12 steps - wikiHow
How-To: Stream almost anything using VLC -- Engadget
Regarding the last link, do not follow any instructions that mention the multicast Wizard, it does not seem to exist in latest version.
You'll may need a geek to set up each individual computer. Although the VLC instructions make it sound easy - it's not easy. I can help though a secure Crossloop session if needed.
One of the PC's needs to be the "server." Doesn't need to be a particularly powerful computer...just one that you would leave turned on and not allow to ""sleep".
That should do it!
Old 20th January 2010, 06:22 PM   #24
xerocomm's Avatar
Post TIVO content
Scott, What Tivo unit are you using and what Operating System is on your PC? I have a possible application that may pull down the Tivo content but it was designed for the Series 3. Reply back with more informtion. In the mean time, I will look at the code of this application.
Old 20th January 2010, 06:26 PM   #25
xerocomm's Avatar
Post Multicast
Scott,
I am sure you are already aware of this but VLC has a great forum at The VideoLAN Forums • Index page check it out and search for the term "Multcast" - many answers are available on this forum and Google regarding this topic. BEWARE, many routers block Multicast traffic so this will be OK in the LAN but may not work on the WAN.
Old 20th January 2010, 06:28 PM   #26
xerocomm's Avatar
Post Multicast
Originally Posted by gedlee View Post
I can't get iot to work. Sure I can play any song from any computer, but I can do that now. What I can't figure out os how to play the same song, in sych on multiple computers.
Gedlee, Please read the follow up's. I made a mistake and misunderstood the original question but I placed a correct solution up yesterday that should work. Sorry to waste your time.
Old 20th January 2010, 06:39 PM   #27
xerocomm's Avatar
Post http://softsqueeze.sourceforge.net/sync.html
Originally Posted by TheSeekerr View Post
Just wanted to note that my proposed SoftSqueeze solution involved no extra hardware at all, every tool involved is freeware software (and even has the source available, although it'd be a stretch to call it open source since it's developed in house by Slim Devices).
That said, yes, at heart they develop devices for logitech to sell.
Please post back if this Orb solution works out for you, I can think of a few uses for such a thing if it truly can run synchronously requiring nothing but a browser on the client end.
The SoftSqueeze solution is a good one and will meet his needs. The VLC Multicast solution has limitations but is a true production grade product. Although the Softsqueeze solution may be much easier to setup. VLC can be really tricky but once setup is ROCK solid.
I also have issues with Java code, just a security thing.
Here are some of the known issues and solutions with Softsqueeze: Softsqueeze 2.0
Let me know what you use in the end, I would be interested to know if VLC or SoftSqueeze can be setup by a general user. If you read the documentation prior to setup, I am sure you will be able to do it!
Old 20th January 2010, 07:17 PM   #28
gedlee is offline gedlee  United States
gedlee's Avatar
Didn't have much time to play, but Softsqueeze setup just fine and worked just fine under Win XP. But the other machine is Win 7 - 64 bit and I could not get it to output sound, although it setup OK and appears in the list of programs using the sound card. There just wasn't any sound. Media player worked fine. Some issues with Win 7 I expect.
Earl Geddes Gedlee Website
Old 21st January 2010, 06:03 PM   #29
xerocomm's Avatar
Softsqueeze is not coded for Windows 7 and there are known issues with 64-bit Win7 but we may be able to get it to work. What error is displayed when you execute Softsqueeze on Windows 7? If no error, go into the Control Panel, Computer Management and look at the Application and System Event Viewer, any errors logged? What sound card are you using?
Old 24th January 2010, 07:19 AM   #30
TheSeekerr is offline TheSeekerr  Australia
Softsqueeze is old, it's worth trying Squeezeplay (Jive) instead.
Question about distributing audioHide this!Advertise here!
Non-audio question: PDAs carlmart Everything Else 6 15th February 2005 06:13 PM
audio triggering question Mindwarper Parts 2 6th December 2004 10:18 AM
Question about Audio Chating ElectronicsTech Introductions 3 13th September 2004 09:36 AM
Distributing PC Internet audio throughout the house gcsheph Everything Else 4 4th April 2004 04:11 AM
Distributing audio/video throughout home heavy Everything Else 3 22nd July 2003 08:56 PM
Copyright ©1999-2017 diyAudio
